Hinges don't hold lid in place while moving laptop, should I switch to 4kg hinges?
I received my Framework 13 in October last year (2024) and during normal use the hinges are fine. However, when I lift the laptop even slightly more than gently the lid tends to swings open or shut without direct contact. I would prefer the lid to stay put while moving the laptop, even if I have to sacrifice “one handed openability”.
I’m assuming I have the 2nd generation 3.5kg hinges but I don’t know for sure, so my questions are…
  1. How can I tell which version of hinges I have installed on this laptop?
  2. If I do have the 2nd generation 3.5kg hinges, would switching to the 1st gen 4kg hinges improve my situation at all?
I swapped to the 4.0kg hinges for the same reason. I find it improved but did not entirely diminish the issue. It’s enough of an improvement that I am happy, but an abrupt enough upward jerk might still cause the lid to flop backwards.
Did you swap from the 2nd generation 3.5kg hinges?
That I’m not super sure about, as I don’t entirely know what defines the generations. I bought this laptop about a year and a half ago, so…maybe. The original hinges were quite floppy, I’ll say that much.
Yeah, that’s what I’m wondering as well. Thanks for your input.
Have you contacted support? They can help with any available options.
I just put the 4kg hinges into my 12th gen FW 13, it made a world of difference for me. I had the same problem of moving around the house and the screen would go whichever way gravity wanted it to. Now it stays in place.
I ended up installing 4kg hinges and also agree they make a big difference.
Personally, I’d stick with the lower-torque hinges after reading about all the broken displays from seemingly gentle handling (i.e. “i just pushed on the bezel with my finger and it got black lines and I had to replace the display”).
Stiffening the hinges increases the strain on the lid and thus the display panel.
