[Honeywell PTM7950 Phase Change Thermal Pads/Sheets] Application, Tips, and Results
Was messing with those at one point before I caved and tried umaf, at least back then they didn’t seem to do all that much.
I am still just using the power and temp limits in ryzenad and just leave stapm turned off in bios/umaf, I am using my own skin temp management (if hurt don’t put on skin XD).
I do get why they need skin temp management but they could at least have used an actual skin temp sensor instead of just guessing the skin temp.
Apparently they do have sensors but it’s not exposed. I played video games without any BIOS or ryzenadj settings. After power goes down to 28W I lifted the laptop and used two desk fans to blow into the bottom surface of the laptop, after a minute the power slowly but surely went back to 33W. If repasting/LMing lower the Tctl but power still reduced to 28W, not repasting but cools the outer surface of the laptop increase power to 33W, apparently there’s a sensor.
Are you sure that wasn’t just because it dropped below 80c for long enough?
Edit: I just checked my spreadsheet, without bypassing stapm mine can do 33W while staying under 80C (both with tpm and lm). With a temp limit set to 80 you’ll never get stapm throttled but you also won’t get a lot more than 33W with the stock heatsink.
No, and paradoxically, using a desk fan increases the CPU temp!
Notice and compare CPU (Tctl/Tdie), CPU Skin Temperature, CPU Package Power, CPU PPT SLOW Limit % and APU STAPM Limit %.
As shown, when running GPU load, the temperatures were well below 80C but STAPM capped power to a solid 28W and the cooling fan ran at max RPM, using a desk fan to cool the bottom surface increased the power between 28W and 33W. When running CPU load, the STAPM didn’t cut power all the way and the fan ran slower despite the CPU temp (Tctl) is much higher. Using a desk fan to cool the skin even makes the Tctl temp increased to 100C, triggering TjMax thermal throttling.
My explanation is the temperature between junction and skin depends on thermal conductivity. The better the thermal conductivity the lower the CPU temp the higher the skin temp. in the Ryzen 7, the iGPU has larger surface area than the CPU, thus at a given cooling system, both thermal conductivity(K) and thickness(d) are constant, for iGPU load, the cross-sectional area(A) is much larger than CPU load. For single-core CPU load, the A is even smaller. That’s probably why High CPU temperatures at low utilization. The fan of the FL13 does not consider Tctl, that’s why the fan slows down on CPU load.
In conclusion, improve the thermal conductivity by repasting/PTM7950/LMing will reduce the CPU temperature, but it might increase the skin temperature, making bypassing the STAPM limit even more necessary. This applies only to FL13, on FL16 the opposite is true as the power is often capped by Tctl due to uneven thermals, in this case, repasting increases CPU power.
I wonder if we are using different sensors, I have never had stapm throttling under 80C but I am not 100% sure what sensor I looked at for that.
Looking at the stapm throttling it really was just decrementing the power by some factor over time as slong as it was over 80 and incrementing when under 80.
While I do agree that ptm/lm increases skin temperature I think it is because you have a lower fan speed for the same power output.
It’s also why you should not run the fw passive even if it can totally run like 10-15W without any fan pretty much indefinitely, the skin temp just gets extremely/illegaly hot.
Given it is pretty much not necessary at all with the stock paste that is a pretty reasonable statement XD.
In my case I have a dbrand skin on it which makes skin temperature a lot less of an issue for me but an even bigger one for the computer XD
I applied PTM7950
PTM7950
The results are significant
28W, 10C cooler
33W, 14C cooler
Single Core, 13C cooler
I used ryzenadj to boost the power to 41W without overheating
41W, 14000+
The score exceeds 14000, higher than some FL16s with uneven thermals.
Hey! Just applied PTM7950 (bought directly from LTT store) on my framework laptop and am seeing some outstanding results. See below:
Ambient Temperature is 67.2 degrees F (am trying to save on heating bills in the winter here!). Am also running my Framework laptop on a vertical stand with a small USB fan running behind the laptop right over the fan vent.
Specs: Framework Laptop 13, Ryzen 7640U mainboard, 32 GB DDR5-5600 from Framework, 2TB Samsung 970 Pro SSD
Please let me know if these results are similar to what you are seeing.
Also Merry Christmas everyone!
Late update, but I wanted to report back.
I’ve removed the heat spreader, cleaned the old thermal paste and applied the Thermal Grizzly pads. That was two weeks ago.
Installation wasn’t that easy. I stored the pads in the fridge before installation and applying them to the CPU was no problem, but when I tried to remove the protective foil from the top, the pad partially stuck to the foil instead of the CPU. Based on reviews, this seems to be a common issue.
In the end, the pad ripped a bit, and it took some fiddling to get it stuck onto the cpu, but I figured it would probably melt together reasonably well in use, even with the botched installation.
I haven’t done any scientific tests on my AMD Framework 13, but subjectively, the system now seems to run much quieter and the fan doesn’t ramp up as much, even under full load.
It is fine if you minimize the gap as much as possible where the rip happened. After a load cycle, paste at 40 C should liquefy and fill in the gaps if the pressure from mounting the heatsink does not. I find it easier to apply when I use angled tweezers.
Just heard about Framework 2nd Gen presentation about Honeywell PCTP being used and was wondering if Framework uses PTM7950 or something else. I have some servers that operate at their thermal limits due to limited cooling and was wondering if it would help.
Is this or another thermal pad being planned to be sold by Framework, separate from the new 13" mainboard?
@Arcadiy_Ivanov1
FW use PTM7958. It is essentially PTM7950 that can be used more easily in the manufacturing process.
Does current batches of older 7040 series come also with PTM?
