How big is the micro SD expansion card for #16
Not sure what you’re asking. Could you rephrase the question?
The micro SD expansion card is the same size as all the other normal expansion cards.
Sorry. I was trying to ask how many GB? From what I’ve read, it seems to be 32GB.
It does not include any MicroSD card. You would bring your own.
As MJ1 said it is just a slot to insert a micro SD card and it does not contain one. I do not think there is any max supported size either, just whatever sized microSD card you can get a hold of. I have used it with up to 1TB microSD cards without any issues.
There is like 2mm of the microSD card left poking out when the microSD is inserted and it just pushes in and out, there is no spring mechanism to be felt when inserting or removing them.
Got it! Thanks.
