How can I save my original FW13
I have a Framework 13 from 2021 and it has some miles on it. I want to refresh it and looking into the best way to do so.
I purchased this laptop from Framework and have not invested in it since. So it does not have some of the original upgrades like the upgraded hinge. I know there were a few upgrades from the original design but I don’t know all of them.
Also, my dog took my laptop for a ride off my desk dented the case, and damaged the fan and the trackpad stopped working.
Here are the specs.
11th gen Intel i7-1165G7
2X16GB Crucial DDR4
WD 1tb nvme
Wi-Fi 6 Intel Chip
BOE CQ LCD monitor
possible upgrade list.
Ryzen 7 main board $650
2X16 DDR5 $160
linus keyboard $100
wifi module $20
hinge kit $25
touch pad $40
web camera $40
total = $1,035
A brand new laptop with an unbent case and a trackpad I do not have to debug and all the other little things fixed is $200 more expensive.
new FW 13
total = $1,259.00
I don’t want to turn this into ewaste. What is the best way to give this computer a better life?
I’d get a ryzen 5 mainboard for ~$450, 2x16gb ddr5 for ~$80 not from framework, just the linux keyboard and not the whole input cover for ~$50, the wifi module you have is good enough, and the newer webcam is a good buy. That totals $620 rather than $1035.
I agree, I’d get the Ryzen 5 mainboard, the minor performance difference doesn’t warrant the large price increase. You can buy similar RAM from Amazon or wherever, much cheaper. And there’s probably no need to get another Wifi module. The Intel AX200/AX210 one works fine on the AMD Laptop, probably even better as the AMD module (as long as you bought the DIY model, the prebuilds with a model number ending in 1 use a weird chip that only works on Intel mainboards).
Contrary to what @HardHat_Media wrote, I’d definitely replace the whole input cover and not only the keyboard. First of all your touchpad seems to be broken anyway, secondly, replacing the keyboard only requires replacing “hundreds” of tiny screws, this is really not fun to do and there’s a large chance to mess something up, IMO the price increase of the input cover is well worth it.
The input cover kit contains the touchpad, so no need to buy it again separately.
So basically my recommendation:
Ryzen 5 mainboard $420
2X16 DDR5 $80
linux input cover $100
wifi module $20
hinge kit $25
touch pad $40
web camera $40 (optional)
This is between $600 and $700, much more reasonable. You might also need a new fan and/or bottom panel of course.
One upgrade you’re missing is the new screen, but if you add that it’s obviously getting more expensive again.
That said, it can of course make sense to simply buy the new model and sell the old laptop for parts, especially if there are lots of broken things.
Hinge kit is definitely a worthwhile upgrade.
RZ616 is MT7922 chip based. I have not used that one personally, but there are folks that aren’t happy with the drivers for that. There are tons of other WiFi card options. Even WiFi 7-ish options such as BE200, MT7925 are like ~$25 now.
Old mainboard does not need to be e-waste. It’s a perfectly functional computer all on its own. Makes a great router, NAS device, home lab, Home Assistant runner, etc.
I could do the Ryzen 5 but that would be the same cost saving on the new build too.
I didn’t mention this but my dog damaged the cover from the fall so I wanted to replace it anyways. but that is not strickly necessary.
This is a little bit of savings. I might do this to get a few more years out of the laptop.
I think selling it might be my best option.
I was hoping there would be a good way to continue to build out the laptop over years.
oh if the touchpad is broken then youre right, honestly thats probably what I would do (also the hinge kit is a good buy would recommend)
If you wanted to save a little more money, you could go with the i5 1340p motherboard for the same price as the 7640u board and keep using your ddr4. the final build would come out to about $545 without the new webcam or 585 with it. Keep in mind that for a laptop built this well with similar performance it probably would start at around 1.5x-2x the cost of this upgrade. You can also pick up a $40 mainboard case and use your old motherboard as a server with some e-waste ddr4 or something, it should be great for that compared to most desktop hardware based servers in terms of cost of power to run it
That could work. I don’t really need a server right now and I need to fix the fan.
New motherboards come with a new fan.
Additionally you can buy the coolers on the website
the old motherboard would probably also still sell for easily $80,
plus some small amounts for DDR4 Ram, old webcam etc.
That should lower the costs a bit more.
