is it possible to order the diy framework with the matte display or do i have to buy that separately and switch it myself, i can find any option to change the display type when im configuring the laptop
The 13th gen Intel and AMD FW13s come with the matte display by default now.
thank you for clarifying as i couldn’t find which display type i ordered.
I believe it should be listed under specifications before you begin configuration.
