I’m trying to follow
but I’m using Fedora Silverblue 40, so I can’t install the old Fedora 39 fwupd version using dnf and with the new version it doesn’t seem to find any upgrades:
~$ LANG=en fwupdmgr get-devices 1e8c8470-a49c-571a-82fd-19c9fa32b8c3
Selected device: Fingerprint Sensor
Framework Laptop 13 (AMD Ryzen 7040Series)
??Fingerprint Sensor:
Device ID: 23ec719b6aabc2d2dac5176c232f0da7a21881b0
Summary: Match-On-Chip fingerprint sensor
Current version: 01000320
Vendor: Goodix (USB:0x27C6)
Install Duration: 10 seconds
Serial Number: UIDXXXXXXXX_XXXX_MOC_B0
GUID: 1e8c8470-a49c-571a-82fd-19c9fa32b8c3 ? USB\VID_27C6&PID_609C
Device Flags: ? Updatable
? Device stages updates
? Device can recover flash failures
? Signed Payload
~$ LANG=en fwupdmgr get-updates 1e8c8470-a49c-571a-82fd-19c9fa32b8c3
Devices with no available firmware updates:
? Fingerprint Sensor
No updatable devices
any tips? Perhaps that guide should be updates for Fedora 40?
