[SOLVED] FW13: Need some help updating Fingerprint sensor [Linux noob]
Fedora
Which release version?
fedora 41 (gnome 47)
Which kernel are you using?
Linux 6.12.7-200.fc41.x86_64
03.05
12th Gen Intel® Core™ i5-1240P × 16
Please excuse the possibility of this being a dumb question. Though I have been using Linux for a couple of years, im not very proficient with the deeper lvl functionality.
I am having some trouble updating the fingerprint sensor through gnome software. Im trying to update from version 01000252 to 01000334.
Gnome software shows the error “Device cannot be used during update.”
I have tried:
Rebooting (many times)
loggin in without using fingerprint
Sudo dnf upgrade
Try initiating the firmware upgrade in a terminal. the command for it is sudo fwupdmgr upgrade
That will initiate the firmware upgrade for all available devices and should either succeed or give a more detailed error message that will allow to figure out what’s causing the issue.
Example output (without available updates since i dont have any to apply)
█▓▒░accalia@Framework16░▒▓██▓▒░ Sat Jan 04 10:45:42
~/ sudo fwupdmgr upgrade
[sudo] password for accalia:
Devices with the latest available firmware version:
 • System Firmware
 • UEFI dbx
Devices with no available firmware updates:
 • AMD Radeon RX 7700S
 • Fingerprint Sensor
 • Hub
 • SSD 990 PRO 1TB
█▓▒░accalia@Framework16░▒▓██▓▒░ Sat Jan 04 10:46:02
Thank you! You’re a legend. That worked perfectly!
Happy to help. :slight_smile:
