How would I remove a saved configuration?
How would I remove a saved configuration or is it not possible? there are a few old ones that I don’t wanna see anymore so I came here to ask after not being able to find out. thanks in advance!
Welcome to the community!
Unfortunately, I don’t believe that’s possible. At least, it used to be not possible. So, unless they’ve changed something, I don’t think there’s a way to delete saved configurations.
They may go away after a certain amount of time, but I’m not sure. Right now, I only have FW 12 configurations in my account, and I can’t imagine I wouldn’t have had some FW 13 and 16 configs show up in there at some point, so unless I managed to inadvertently save four FW 12 configs and not a single 13 or 16 config, I’m guessing they drop off after a time. But I can’t say for sure.
Yeah because I have a saved configuration for one of every single model, FW13 some I got and the first FW16 I got but they just don’t go.
I’m also running into the same issue. I have 9 saved configurations, and 4 of them are because I used a saved config link and just changed one option.
The oldest configuration I have is from this year in April, and it hasn’t disappeared yet :confused:
giphy
