IIO-sensor and Auto-rotate on NixOS
I’ve been trying to get my iio-sensor to read on Sway and Hyprland (currently using Sway for off-topic reasons) but both haven’t been able to work properly.
I’m following the guide to add the iio-sway flake.nix module
inputs = {
iio-sway.url = “github:tbaumann/iio-sway”;
outputs = { iio-sway, … }@inputs:
Then in configuration.nix
hardware.sensor.iio.enable = lib.mkDefault true;
Home.nix
imports = [ inputs.iio-sway.homeManagerModules.default ];
programs.iio-sway = {
enable = true;
display = “eDP-1”;
wayland.windowManager.sway.config.startup = [
{command = “iio-sway”; always = true;}
But when i run this is either get
error: undefined variable ‘inputs’
But adding ‘inputs’ to header gives me this error:
error: infinite recursion encountered
Not sure how to fix.
