Which Linux distro are you using? Arch
(If rolling release, last date updated?) 9-11-25
Which kernel are you using? 6.16.6
Which BIOS version are you using? 3.22
Which Framework Laptop 13 model are you using? (AMD Ryzen™ AI 300 Series, AMD Ryzen™ 7040 Series, Intel® Core™ Ultra Series 1, 13th Gen Intel® Core™ , 12th Gen Intel® Core™, 11th Gen Intel® Core™) 11th Gen Intel Core
I’m trying out this package for automatic screen brightness adjustment: GitHub - mikhail-m1/illuminanced: Ambient Light Sensor Daemon for Linux
It works but not very well. It’s too bright all the time, has really dramatic adjustments with the slightest change of light in the room, and screen seems to flicker a bit everytime changes the brightness?
It uses these settings: illuminanced/illuminanced.toml at master · mikhail-m1/illuminanced · GitHub. I had to change the line for the illuminance_file
Does anyone have a good settings for this package? Or any tips at all for automatic adjustment to screen brightness when not using GNOME, KDE, or any desktop environment. I’m using niri window manager.
