Hi Framework Community,
I’ve run into a potential bug. My screen will occasionally change brightness on its own despite having the Setting, “Change brightness automatically when lighting changes” un-selected. Is there another setting I’m unaware of that needs to be turned off also?
This appears to be un-related to the dim my screen setting in the power plan as it will occur while I’m actively using the laptop. It has occurred in low and well lit scenarios. I am not often in moderately lit environments to test this.
I’ve running the 1165-G7, 32GB 3200 ram, 1TB WD 750, 2 USB C, 2 USB A, webcam and microphone switches turned off, and Windows 10 Pro version 10.0.19043, build 19043.
Framework driver package was installed and all other aspects of the laptop function normally.
Anyone have any thoughts?
