Laptop has drivers that are modified by manufacture. If you update the driver a warning appears. How will Framework advise on the drivers to locate and install
We’ll be enabling driver updates through Windows Update, with a fallback manual install package also available.
Thank you the information NRP. This Acer laptop that I own behaves the same with a new update integrated graphic driver. Using userbenchmark.exe and testing i5 9300H core processor, result is good for 3D basic game.
