Is fan performance monitoring possible?
Is it possible to monitor APU or case fan performance of the Desktop in Windows 11? There doesn’t seem to be any support, even in Adrenalin
For an ad hoc solution, you can first install Framework System with:
winget install framework_tool
Then do:
while ($true) { framework_tool.exe --thermal; Start-Sleep -Seconds 1 }
To get the CPU fan RPM only:
while ($true) { framework_tool.exe --thermal | Select-String -Pattern “Fan Speed:” | Select-Object -First 1; Start-Sleep -Seconds 1 }
Thanks for the pointer @gwiazdorrr
At the Windows command prompt this worked for me
framework_tool --thermal
F75303_APU: 47 C
F75303_DDR: 50 C
F75303_AMB: 49 C
APU: 53 C
Temp 4: 50 C
Fan Speed: 0 RPM
Fan Speed: 231 RPM
Fan Speed: 0 RPM
EDIT:
I really wanna see something like this for the PSU fan.
I think the PSU fan stands alone i.e. does not interface with the chipset
Bummer. BTW, Windows 11 recently added the sudo command. I just tried sudo framework_tool –thermals and this automatically elevates permissions for you without a new command window.
That innovative Windows team never ceases to amaze me :joy: What will they think of next?
