on my previous (Lenovo) computer i found i could hit the left function key to wake the machine if it went to sleep while the lid was open.
Is there a similar shortcut on framework? I remember reading that the whole keyboard probably gets disabled when the laptop sleeps but im curious if anyone knows more about this than me. is the power button used as this button?
Works for me on Win 11 dual boot Ubuntu 22 (on both)
What OS are you using?
Using Win 11 I have closing the lid to invoke sleep.
If I use the GUI to select sleep or close the lid, when I open the lid the screen comes on. If I then tap the space bar, or any of the keys mentioned I am back to where I was when I closed the lid or used the GUI to invoke sleep
just tried mashing a bunch of different stuff. also tried capslock to see if the light came on and it didnt, so i suspect that the keyboard isn’t enabled/powered when my laptop is suspended. not sure if that’s normal or not
I just wonder if in the Ubuntu world you are talking about suspend as in ‘suspend to disk’ which is the same as hibernate in windows and that does require the use of the power button to power on.
