Is there a way to reattach a key?
I received my framework laptop today and noticed the F3 key was crooked. Didn’t think much of it until I was trying to change the volume when the key snapped off. Is there a way to reattach it? Do I need to remove the whole keyboard assembly or is there a special way to snap it back on that I can’t figure out?
Though it looks like one of the small plastic connectors on the key itself may be broken.
Check the video for how to reattach a key:
but if the latch tab has broken off, you may have to contact support.
