Issues retaining display setting configuration
Fedora Workstation 43
Which kernel are you using?
Linux 6.17.7-300.fc43.x86_64
Latest update (I updated yesterday)
Laptop 13 (AMD Ryzen AI 300 Series)
AMD Ryzen AI 9 HX 370
The Problem:
I often swap between join monitors and external only with Meta + P depending on what I’m doing. Every time I do this, or if I swap between different monitors, the display configuration resets. This includes position, refresh rate, etc.
The reason I do this is because I like to have my laptop open for ventilation but usually only want one screen. Sometimes, I have issues with my cursor not locking to a fullscreen game when multiple monitors are connected, so I use this as a fix. It also increases performance slightly to be on one monitor.
I usually connect through usb-c, but this also happens on displayport.
