Json_node kind was raw, not object
When I run the firmware update, it’s been taking like 30 seconds lately (maybe a week?), where it used to take about 5.
The terminal readout is
Updating lvfs
Downloading… [ - ]
Successfully downloaded new metadata:
• 5 devices are updatable
• 4 devices are supported in the enabled remotes (an update has been published)
json_node kind was raw, not object
I find literally 0 results for this. Any idea what’s going on?
I am getting this error as well
OS: Fedora 44 KDE
Framework 13 AMD
But I also observed this on a seperate Dell machine with Ubuntu 26 installed, so it might be an upstream issue.
The most recent time I ran it just now, it didn’t take 30 seconds, nor did I get the error.
Typically, for about a month now, it always takes like 30 seconds, and I get the JSON error about once every 4 times.
