Fedora 41 KDE Spin
Which kernel are you using?
Linux 6.13.5-200.fc41.x86_64
Not sure, probably unrelated
Which Framework Laptop 16 model are you using? (AMD Ryzen™ 7040 Series)
Laptop 16 (AMD Ryzen 7040 Series) (AG)
I’m not sure if anyone else has noticed this, but there feels like there’s a huge difference in picture quality between 100% and 150% scaling on Plasma. I am using Wayland but I can’t imagine that makes a huge difference. Basically, it feels like when I’m scaled at 150% that the image quality is “worse”. It reminds me of when you use paint to upscale an image and it anti-aliases the image to try and fill in the blanks. At 100% though, everything is too small and it strains my eyes. I’ve been trying to see if I can just scale every application individually which seems to be working fine for what I can scale. For example, Firefox manually scaled by 1.5 using about:config, looks crisper than when the entire DE is scaled by 1.5. Why is this?
I’ve attached 2 screenshots of the two different settings where you can clearly see the quality difference. (Please disregard my theme, I know it is jarring)
If there’s a good way to make the scaling look crisp like it does when I manually scale things, please let me know because I have not found a way to do it.
