My framework’s keyboard is not responding and the power button LED no longer works. This happened when I turned it on after it was shut. The LED come on for a second then went off. However the rest of the laptop works as normal.
Must be the connection to the mainboard? If everything else works. I would check to see if the cable is connected well! Otherwise contact support if you can’t find a solution!
The issue randomly fixed itself. Possibly a software issue with Windows 11
Hi @Triston_Whitescarver. We suggest updating to BIOS v3.07 and if you are using Windows OS please update the drivers which fixed common issues. You can download through this link : Framework Laptop BIOS and Driver Releases
If this continues to be an issue for you, I would recommend submitting a ticket to our support team here: Framework | Support so they can ensure your laptop is performing as intended!
Have a great day and stay safe.
