Keyboard keys one stroke two actions
Hi,
I have assembled my FL13 and installed EndeavourOS, which is basically arch linux on it. I have a weird Keyboard issue (German Keyboard btw): When I type the letter p the result is a p an cursor movement to the left, as if pressing the left arrow key; if I press the right arrow key, I get cursor movement to the right plus the letter ß. I have toyed around with various keyboard hardware configurations and layouts. I couldn‘t find a Solution. What could be wrong?
EndeavourOS (arch)
Which release version? Mercury
Which kernel are you using?
Which Framework Laptop 13 model are you using? (AMD Ryzen™ 7040 Series)
probably a hardware fault.
The Framework keyboards don’t seem to have proper n-key rollover, the arrow keys, p and SS keys are probably sharing lines. might be worth re connecting the keyboard, unpluging and reconnecting the ribbon cabels.
/Zoe
