This is different to the code on github, for everyones info…
I’m not sure to which github code you are referring, but the steps under the “Permissions on Linux” section assume that you have cloned the repo. They just copy the local version of the file into the necessary directory. The command that CauseOfBSOD noted above downloads only that file from the remote github repo and writes it to the directory on your machine.
If I am misunderstanding something, my apologies. Glad that you got things working. The community here is a great one and very helpful (yours truly excluded, of course). I’ve gotten help countless times and learned a lot. I hope that you enjoy the machine, and have a great evening!
I should probably mention that this code requires a working internet connection, and for github to be online, and does not validate what is downloaded beyond printing it to stdout (consider removing the | and everything after it to check the file before running the command if this post has significant age)
