Why do the USB-C, USB-A, and the SD card module all only have one port? There is enough room for each of them to have more than one. There could be two USB-C ports, or two USB-C ports, or multiple SD card slots including a mini and a full size.
Similarly, there isn’t an option for a mix between the USB ports. A C and A combo on a single exp card. It seems like an inefficient use of space. Is there an internal circuitry or PCB limitation or just a design choice? If so, that would mean someone could create one of these better cards.
