Ubuntu 24.04.2
Which kernel are you using? - 6.11.0-17-generic
Which BIOS version are you using? - 03.05
Which Framework Laptop 16 model are you using? - Framework 16 Ryzen 7 7840HS, Radeon RX 7700S.
All help appreciated! I’m happy to provide more logs or redirect this question to other forums as needed.
First I’ll cover behavior, then current troubleshooting attempts, then hardware details, then my known logs.
Core behavior:
I have a Dell USB Hub that connects to my FW16 for several USB devices (Mouse, Keyboard, Mic, etc), as well as my displays through Display port. When in a Discord voice call, my USB devices seem to disconnect, and take 20-30s to reconnect. This happens frequently, and has only been observed while my mic is active in a discord voice chat. The result is that I lose access to mouse, keyboard, usb speakers, and microphone, all defaulting to the options on the Framework chassis. This happens at irregular intervals, but is fairly (and annoyingly) frequent.
Important detail - The external displays do NOT disconnect during this time, despite also being connected to the laptop through the same Dell USB hub.
Troubleshooting attempts:
- All of this hardware is new, so I don’t have extended experience, but it has been over a week trying to resolve this issue on my own now without success.
- First step seems like that using my mic in combination with my other devices is too much for my hub to handle. However, I’ve used other applications with the microphone (Google meet) for an hour+ without running into the issue. I’ve also used another laptop running a different Debian distro that uses that same hub, with the same peripherals, with both my mic AND camera on for Google meet for multiple hours with no issues as well.
- I’ve tried uninstalling and reinstalling Discord, as well as switching between versions (snap install, vs .deb downloaded from the Discord website.)
- I’ve update the hub’s firmware, and also downgraded it to every available version of firmware currently available.
- Leaving the mic muted in discord nearly eliminates the issue, but it seems that it still rarely occurs even while muted if I’m in the call. (Possibly related to transitioning on and off during push to talk though). Edit 2025-02-16: Forcibly gathered more cases where being in a discord call while muted, with others still speaking, till causes the disconnect
- I’ve tried switching some of the USB ports being used to a different secondary hub with dedicated power. So thats a DC-powered hub plugged directly into another DC-powered hub, but the issue still persisted.
- Minimal applications foreground applications have usually been open while this has occurred. It occurred with only Google Chrome and Discord open. It occurred with only Discord, Steam, and Tabletop Simulator open.
- Sitting in an empty discord chat, with my mic unmuted, with no audio being played from any application. The issue still occurs here.
- Moving the Anker USB hub to a different Dell USB hub port does not help.
Hardware details:
- The included 180 W power adapter is plugged into expansion slot 1.
- The Dell USB hub is plugged into expansion slot 4.
- The USB hub is a Dell WD19S 130W
- Two Monitors are connected via display ports.
- One of the monitors I’m using as a USB A passthrough for my Blue Snowball Ice Microphone and my logitech C615 Webcam. This connection is using the bottom-back port on the Dell dock. The webcam is generally not active when the issue occurs.
- The top-back port on the dell dock is connected to an Anker Ultra Slim 4-port USB data hub
(As an alternative to the Anker hub, I’ve also tried using a direct-powered UGREEN USB 3.0 4-port switch, which was seeing the same issue)
Connected to the hub are: - A wireless dongle for a Keychron Q3 Max keyboard.
- A wireless dongle for a Razer Naga V2 HyperSpeed mouse.
- A wireless dongle for an 8bitDo Ultimate 2C Wireless controller. Generally not active when the issue occurs.
- A Sound BlasterX G1 portable sound card.
Short version - I have a wireless keyboard dongle, wireless mouse dongle, and a sound card dongle attached to a hub, which itself is attached to a hub, which has another hub/passthrough attached to a different port with a microphone connection. These connection all seem to disappear at the same time, though the display port connections have always remained entirely stable.
Known logs:
There are no logs in /var/crash.
dmesg shows a ton of entries for:
audit: type=1400 audit(1739747156.281:1656277): apparmor="DENIED" operation="ptrace" class="ptrace" profile="snap.discord.discord" pid=82141 comm="Utils" requested_mask="read" denied_mask="read" peer="unconfined"
Though light searching on this makes it seem specific to the snap version of discord, so maybe I’ll reinstall a different version later. Part of this concerns me, I hope it’s related to the kauditd_printk_skb: 239 callbacks suppressed that continuously increases.
More likely important/Interesting occurrences near the time of error through dmesg:
[35661.065608] usb 5-1.3.2.2: USB disconnect, device number 100
[35661.156124] usb 5-1.3.2.2: new high-speed USB device number 101 using xhci_hcd
[35661.444456] usb 5-1.3.2.2: New USB device found, idVendor=046d, idProduct=082c, bcdDevice= 0.11
[35661.444469] usb 5-1.3.2.2: New USB device strings: Mfr=0, Product=2, SerialNumber=1
[35661.444474] usb 5-1.3.2.2: Product: HD Webcam C615
[35661.444479] usb 5-1.3.2.2: SerialNumber: 9564E950
[35662.033768] usb 5-1.3.2.2: Found UVC 1.00 device HD Webcam C615 (046d:082c)
[35883.708050] hub 5-1.3.2:1.0: hub_ext_port_status failed (err = -71)
[35884.822736] usb 5-1.3.3: clear tt 1 (00d0) error -71
[35884.824297] usb 5-1.3.3-port1: cannot reset (err = -71)
[35884.824671] usb 5-1.3.3-port1: cannot reset (err = -71)
[35884.825045] usb 5-1.3.3-port1: cannot reset (err = -71)
[35884.825421] usb 5-1.3.3-port1: cannot reset (err = -71)
[35884.825798] usb 5-1.3.3-port1: cannot reset (err = -71)
[35884.825800] usb 5-1.3.3-port1: Cannot enable. Maybe the USB cable is bad?
[35884.826172] usb 5-1.3.3-port1: cannot disable (err = -71)
[35884.826547] usb 5-1.3.3-port1: cannot reset (err = -71)
[35884.826922] usb 5-1.3.3-port1: cannot reset (err = -71)
[35884.827283] usb 5-1.3.3-port1: cannot reset (err = -71)
[35884.827671] usb 5-1.3.3-port1: cannot reset (err = -71)
[35884.828046] usb 5-1.3.3-port1: cannot reset (err = -71)
[35884.828050] usb 5-1.3.3-port1: Cannot enable. Maybe the USB cable is bad?
[35884.828452] usb 5-1.3.3-port1: cannot disable (err = -71)
[35884.828823] usb 5-1.3.3-port1: cannot reset (err = -71)
[35884.829158] usb 5-1.3.3-port1: cannot reset (err = -71)
[35884.829538] usb 5-1.3.3-port1: cannot reset (err = -71)
[35884.829920] usb 5-1.3.3-port1: cannot reset (err = -71)
[35884.830295] usb 5-1.3.3-port1: cannot reset (err = -71)
[35884.830298] usb 5-1.3.3-port1: Cannot enable. Maybe the USB cable is bad?
[35884.830672] usb 5-1.3.3-port1: cannot disable (err = -71)
[35884.831047] usb 5-1.3.3-port1: cannot reset (err = -71)
[35884.831419] usb 5-1.3.3-port1: cannot reset (err = -71)
[35884.831799] usb 5-1.3.3-port1: cannot reset (err = -71)
[35884.832167] usb 5-1.3.3-port1: cannot reset (err = -71)
[35884.832546] usb 5-1.3.3-port1: cannot reset (err = -71)
[35884.832549] usb 5-1.3.3-port1: Cannot enable. Maybe the USB cable is bad?
[35884.832921] usb 5-1.3.3-port1: cannot disable (err = -71)
[35884.833298] usb 5-1.3.3-port4: cannot reset (err = -71)
[35884.833672] usb 5-1.3.3-port1: cannot disable (err = -71)
[35884.834082] usb 5-1.3.3-port4: cannot reset (err = -71)
[35884.834423] hub 5-1.3.3:1.0: hub_ext_port_status failed (err = -71)
[35884.834797] usb 5-1.3.3-port4: cannot reset (err = -71)
[35884.835252] usb 5-1.3.3-port4: cannot reset (err = -71)
[35884.835541] usb 5-1.3.3-port4: cannot reset (err = -71)
[35884.835543] usb 5-1.3.3-port4: Cannot enable. Maybe the USB cable is bad?
[35884.835919] usb 5-1.3.3-port4: cannot disable (err = -71)
[35884.836294] usb 5-1.3.3-port4: cannot reset (err = -71)
[35884.836670] usb 5-1.3.3-port4: cannot reset (err = -71)
[35884.837045] usb 5-1.3.3-port4: cannot reset (err = -71)
[35884.837420] usb 5-1.3.3-port4: cannot reset (err = -71)
[35884.837797] usb 5-1.3.3-port4: cannot reset (err = -71)
[35884.837800] usb 5-1.3.3-port4: Cannot enable. Maybe the USB cable is bad?
[35884.838172] usb 5-1.3.3-port4: cannot disable (err = -71)
[35884.838547] usb 5-1.3.3-port4: cannot reset (err = -71)
[35884.838922] usb 5-1.3.3-port4: cannot reset (err = -71)
[35884.839300] usb 5-1.3.3-port4: cannot reset (err = -71)
[35884.839672] usb 5-1.3.3-port4: cannot reset (err = -71)
[35884.840048] usb 5-1.3.3-port4: cannot reset (err = -71)
[35884.840051] usb 5-1.3.3-port4: Cannot enable. Maybe the USB cable is bad?
[35884.840420] usb 5-1.3.3-port4: cannot disable (err = -71)
[35884.840797] usb 5-1.3.3-port4: cannot reset (err = -71)
[35884.841173] usb 5-1.3.3-port4: cannot reset (err = -71)
[35884.841547] usb 5-1.3.3-port4: cannot reset (err = -71)
[35884.841922] usb 5-1.3.3-port4: cannot reset (err = -71)
[35884.842284] usb 5-1.3.3-port4: cannot reset (err = -71)
[35884.842288] usb 5-1.3.3-port4: Cannot enable. Maybe the USB cable is bad?
[35884.842671] usb 5-1.3.3-port4: cannot disable (err = -71)
[35884.843047] usb 5-1.3.3-port4: cannot disable (err = -71)
[35884.843422] usb 5-1.3.3-port3: cannot reset (err = -71)
[35884.843802] hub 5-1.3.3:1.0: hub_ext_port_status failed (err = -71)
[35884.844299] usb 5-1.3.3-port3: cannot reset (err = -71)
[35884.844551] hub 5-1.3.3:1.0: hub_ext_port_status failed (err = -71)
[35884.844921] usb 5-1.3.3-port3: cannot reset (err = -71)
[35884.845298] usb 5-1.3.3-port3: cannot reset (err = -71)
[35884.845670] usb 5-1.3.3-port3: cannot reset (err = -71)
[35884.845673] usb 5-1.3.3-port3: Cannot enable. Maybe the USB cable is bad?
[35884.846046] usb 5-1.3.3-port3: cannot disable (err = -71)
[35884.846420] usb 5-1.3.3-port3: cannot reset (err = -71)
[35884.846797] usb 5-1.3.3-port3: cannot reset (err = -71)
[35884.847172] usb 5-1.3.3-port3: cannot reset (err = -71)
[35884.847548] usb 5-1.3.3-port3: cannot reset (err = -71)
[35884.847923] usb 5-1.3.3-port3: cannot reset (err = -71)
[35884.847926] usb 5-1.3.3-port3: Cannot enable. Maybe the USB cable is bad?
[35884.848286] usb 5-1.3.3-port3: cannot disable (err = -71)
[35884.848672] usb 5-1.3.3-port3: cannot reset (err = -71)
[35884.849068] usb 5-1.3.3-port3: cannot reset (err = -71)
[35884.849419] usb 5-1.3.3-port3: cannot reset (err = -71)
[35884.849796] usb 5-1.3.3-port3: cannot reset (err = -71)
[35884.850197] usb 5-1.3.3-port3: cannot reset (err = -71)
[35884.850200] usb 5-1.3.3-port3: Cannot enable. Maybe the USB cable is bad?
[35884.850545] usb 5-1.3.3-port3: cannot disable (err = -71)
[35884.850922] usb 5-1.3.3-port3: cannot reset (err = -71)
[35884.851282] usb 5-1.3.3-port3: cannot reset (err = -71)
[35884.851670] usb 5-1.3.3-port3: cannot reset (err = -71)
[35884.852046] usb 5-1.3.3-port3: cannot reset (err = -71)
[35884.852421] usb 5-1.3.3-port3: cannot reset (err = -71)
[35884.852424] usb 5-1.3.3-port3: Cannot enable. Maybe the USB cable is bad?
[35884.852798] usb 5-1.3.3-port3: cannot disable (err = -71)
[35884.853171] usb 5-1.3.3-port3: cannot disable (err = -71)
[35884.853549] hub 5-1.3.3:1.0: hub_ext_port_status failed (err = -71)
[35884.853922] hub 5-1.3.3:1.0: hub_ext_port_status failed (err = -71)
[35884.854298] hub 5-1.3.3:1.0: hub_ext_port_status failed (err = -71)
[35885.344731] retire_capture_urb: 1948 callbacks suppressed
[35888.966967] usb 5-1.3.2.2: Failed to suspend device, error -71
retire_capture_urb: 5304 callbacks suppressed
[35891.351207] usb 5-1.3: USB disconnect, device number 89
[35891.351220] usb 5-1.3.2: USB disconnect, device number 91
[35891.351226] usb 5-1.3.2.1: USB disconnect, device number 93
[35891.382822] usb 5-1.3.2.2: USB disconnect, device number 101
[35891.446921] usb 5-1.3.3: USB disconnect, device number 92
[35891.446934] usb 5-1.3.3.1: USB disconnect, device number 95
[35891.510761] usb 5-1.3.3.2: USB disconnect, device number 96
[35891.542833] usb 5-1.3.3.3: USB disconnect, device number 97
[35891.799256] usb 5-1.3.3.4: USB disconnect, device number 98
[35891.991371] usb 5-1.3.5: USB disconnect, device number 94
[35892.055896] usb 5-1.5: USB disconnect, device number 90
[35892.214769] usb 5-1: reset high-speed USB device number 2 using xhci_hcd
[35892.701062] usb 5-1.3: new high-speed USB device number 102 using xhci_hcd
[35892.810986] usb 5-1.3: New USB device found, idVendor=0bda, idProduct=5413, bcdDevice= 1.23
[35892.811006] usb 5-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[35892.811011] usb 5-1.3: Product: Dell dock
[35892.811014] usb 5-1.3: Manufacturer: Dell Inc.
[35892.855887] hub 5-1.3:1.0: USB hub found
[35892.857234] hub 5-1.3:1.0: 6 ports detected
[35893.000111] usb 5-1.5: new high-speed USB device number 103 using xhci_hcd
[35893.091487] usb 5-1.5: New USB device found, idVendor=413c, idProduct=b06e, bcdDevice= 1.01
[35893.091495] usb 5-1.5: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[35893.091497] usb 5-1.5: Product: Dell dock
[35893.143681] hid-generic 0003:413C:B06E.0115: hiddev1,hidraw3: USB HID v1.11 Device [Dell dock] on usb-0000:c7:00.4-1.5/input0
[35893.219827] usb 5-1.3.2: new high-speed USB device number 104 using xhci_hcd
[35893.314744] usb 5-1.3.2: New USB device found, idVendor=2109, idProduct=2811, bcdDevice=90.90
[35893.314759] usb 5-1.3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[35893.314766] usb 5-1.3.2: Product: USB2.0 Hub
[35893.314771] usb 5-1.3.2: Manufacturer: VIA Labs, Inc.
[35893.367652] hub 5-1.3.2:1.0: USB hub found
[35893.368156] hub 5-1.3.2:1.0: 4 ports detected
[35893.459096] usb 5-1.3.3: new high-speed USB device number 105 using xhci_hcd
[35893.562161] usb 5-1.3.3: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 1.01
[35893.562175] usb 5-1.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[35893.562182] usb 5-1.3.3: Product: USB2.1 Hub
[35893.562188] usb 5-1.3.3: Manufacturer: Generic
[35893.623452] hub 5-1.3.3:1.0: USB hub found
[35893.624375] hub 5-1.3.3:1.0: 5 ports detected
[35893.700097] usb 5-1.3.2.1: new full-speed USB device number 106 using xhci_hcd
[35893.811415] usb 5-1.3.2.1: New USB device found, idVendor=0d8c, idProduct=0005, bcdDevice= 1.00
[35893.811431] usb 5-1.3.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[35893.811437] usb 5-1.3.2.1: Product: Blue Snowball
[35893.811443] usb 5-1.3.2.1: Manufacturer: BLUE MICROPHONE
[35893.811447] usb 5-1.3.2.1: SerialNumber: 201306
[35893.869261] usb 5-1.3.5: new high-speed USB device number 107 using xhci_hcd
[35893.974670] hid-generic 0003:0D8C:0005.0116: No inputs registered, leaving
[35893.974751] hid-generic 0003:0D8C:0005.0116: hidraw4: USB HID v1.11 Device [BLUE MICROPHONE Blue Snowball ] on usb-0000:c7:00.4-1.3.2.1/input2
[35893.982862] usb 5-1.3.5: New USB device found, idVendor=413c, idProduct=b06f, bcdDevice= 1.01
[35893.982868] usb 5-1.3.5: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[35893.982872] usb 5-1.3.5: Product: Dell dock
[35894.042396] hid-generic 0003:413C:B06F.0117: hiddev3,hidraw7: USB HID v1.11 Device [Dell dock] on usb-0000:c7:00.4-1.3.5/input0
[35894.055103] usb 5-1.3.3.1: new full-speed USB device number 108 using xhci_hcd
[35894.091127] hid-generic 0003:413C:B06F.0118: hiddev1,hidraw3: USB HID v1.11 Device [Dell dock] on usb-0000:c7:00.4-1.3.5/input0
[35894.157543] hid-generic 0003:413C:B06E.0119: hiddev3,hidraw7: USB HID v1.11 Device [Dell dock] on usb-0000:c7:00.4-1.5/input0
[35894.199579] usb 5-1.3.3.1: New USB device found, idVendor=041e, idProduct=3249, bcdDevice=10.13
[35894.199593] usb 5-1.3.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[35894.199600] usb 5-1.3.3.1: Product: Sound BlasterX G1
[35894.199605] usb 5-1.3.3.1: Manufacturer: Creative Technology Ltd
[35894.199609] usb 5-1.3.3.1: SerialNumber: 00170207
[35894.553766] input: Creative Technology Ltd Sound BlasterX G1 Consumer Control as /devices/pci0000:00/0000:00:08.3/0000:c7:00.4/usb5/5-1/5-1.3/5-1.3.3/5-1.3.3.1/5-1.3.3.1:1.3/0003:041E:3249.011A/input/input215
[35894.605524] hid-generic 0003:041E:3249.011A: input,hiddev3,hidraw7: USB HID v1.11 Device [Creative Technology Ltd Sound BlasterX G1] on usb-0000:c7:00.4-1.3.3.1/input3
[35894.683021] usb 5-1.3.3.2: new full-speed USB device number 109 using xhci_hcd
[35894.793642] usb 5-1.3.3.2: New USB device found, idVendor=2dc8, idProduct=301c, bcdDevice= 2.00
[35894.793659] usb 5-1.3.3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[35894.793666] usb 5-1.3.3.2: Product: IDLE
[35894.793672] usb 5-1.3.3.2: Manufacturer: 8BitDo
[35894.793676] usb 5-1.3.3.2: SerialNumber: B1FB23200E
[35894.880153] hid-generic 0003:2DC8:301C.011B: hiddev5,hidraw10: USB HID v1.10 Device [8BitDo IDLE] on usb-0000:c7:00.4-1.3.3.2/input0
[35894.957036] usb 5-1.3.3.3: new full-speed USB device number 110 using xhci_hcd
[35894.961994] hid-generic 0003:413C:B06E.011C: hiddev6,hidraw11: USB HID v1.11 Device [Dell dock] on usb-0000:c7:00.4-1.5/input0
[35895.069544] usb 5-1.3.3.3: New USB device found, idVendor=1532, idProduct=00b4, bcdDevice= 1.00
[35895.069560] usb 5-1.3.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[35895.069568] usb 5-1.3.3.3: Product: Razer Naga V2 HyperSpeed
[35895.069573] usb 5-1.3.3.3: Manufacturer: Razer
[35895.069578] usb 5-1.3.3.3: SerialNumber: 000000000000
[35895.202667] input: Razer Razer Naga V2 HyperSpeed as /devices/pci0000:00/0000:00:08.3/0000:c7:00.4/usb5/5-1/5-1.3/5-1.3.3/5-1.3.3.3/5-1.3.3.3:1.0/0003:1532:00B4.011D/input/input217
[35895.202854] hid-generic 0003:1532:00B4.011D: input,hidraw12: USB HID v1.11 Mouse [Razer Razer Naga V2 HyperSpeed] on usb-0000:c7:00.4-1.3.3.3/input0
[35895.210808] input: Razer Razer Naga V2 HyperSpeed Keyboard as /devices/pci0000:00/0000:00:08.3/0000:c7:00.4/usb5/5-1/5-1.3/5-1.3.3/5-1.3.3.3/5-1.3.3.3:1.1/0003:1532:00B4.011E/input/input218
[35895.293067] input: Razer Razer Naga V2 HyperSpeed Mouse as /devices/pci0000:00/0000:00:08.3/0000:c7:00.4/usb5/5-1/5-1.3/5-1.3.3/5-1.3.3.3/5-1.3.3.3:1.1/0003:1532:00B4.011E/input/input219
[35895.293186] input: Razer Razer Naga V2 HyperSpeed as /devices/pci0000:00/0000:00:08.3/0000:c7:00.4/usb5/5-1/5-1.3/5-1.3.3/5-1.3.3.3/5-1.3.3.3:1.1/0003:1532:00B4.011E/input/input220
[35895.293262] hid-generic 0003:1532:00B4.011E: input,hidraw13: USB HID v1.11 Keyboard [Razer Razer Naga V2 HyperSpeed] on usb-0000:c7:00.4-1.3.3.3/input1
[35895.300081] input: Razer Razer Naga V2 HyperSpeed as /devices/pci0000:00/0000:00:08.3/0000:c7:00.4/usb5/5-1/5-1.3/5-1.3.3/5-1.3.3.3/5-1.3.3.3:1.2/0003:1532:00B4.011F/input/input221
[35895.382336] hid-generic 0003:1532:00B4.011F: input,hidraw14: USB HID v1.11 Keyboard [Razer Razer Naga V2 HyperSpeed] on usb-0000:c7:00.4-1.3.3.3/input2
usb 5-1.3.3.4: new full-speed USB device number 111 using xhci_hcd
[35895.567670] usb 5-1.3.3.4: New USB device found, idVendor=3434, idProduct=d030, bcdDevice=d2.04
[35895.567686] usb 5-1.3.3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[35895.567693] usb 5-1.3.3.4: Product: Keychron Link
[35895.567699] usb 5-1.3.3.4: Manufacturer: Keychron
[35895.708837] input: Keychron Keychron Link as /devices/pci0000:00/0000:00:08.3/0000:c7:00.4/usb5/5-1/5-1.3/5-1.3.3/5-1.3.3.4/5-1.3.3.4:1.0/0003:3434:D030.0120/input/input222
[35895.709274] hid-generic 0003:3434:D030.0120: input,hidraw15: USB HID v1.11 Mouse [Keychron Keychron Link ] on usb-0000:c7:00.4-1.3.3.4/input0
[35895.715031] hid-generic 0003:3434:D030.0121: hiddev7,hidraw16: USB HID v1.11 Device [Keychron Keychron Link ] on usb-0000:c7:00.4-1.3.3.4/input1
[35895.721102] input: Keychron Keychron Link Keyboard as /devices/pci0000:00/0000:00:08.3/0000:c7:00.4/usb5/5-1/5-1.3/5-1.3.3/5-1.3.3.4/5-1.3.3.4:1.2/0003:3434:D030.0122/input/input223
[35895.812212] hid-generic 0003:3434:D030.0122: input,hidraw17: USB HID v1.11 Keyboard [Keychron Keychron Link ] on usb-0000:c7:00.4-1.3.3.4/input2
[35895.892024] usb 5-1.3.2.2: new high-speed USB device number 112 using xhci_hcd
[35896.193500] usb 5-1.3.2.2: New USB device found, idVendor=046d, idProduct=082c, bcdDevice= 0.11
[35896.193511] usb 5-1.3.2.2: New USB device strings: Mfr=0, Product=2, SerialNumber=1
[35896.193515] usb 5-1.3.2.2: Product: HD Webcam C615
[35896.193519] usb 5-1.3.2.2: SerialNumber: 9564E950
[35896.912650] usb 5-1.3.2.2: Found UVC 1.00 device HD Webcam C615 (046d:082c)
[35901.942606] usb 5-1.3.2.2: reset high-speed USB device number 112 using xhci_hcd
From this, it looks like the main source of the errors is in my 4-port anker hub connected to the Dell hub. However, this is also the piece that I’ve swapped for a different hub during my troubleshooting. This hub contains keyboard, mouse, controller, and audio dongles, NOT the microphone dongle, yet the issue seems to only occur with active Microphone activity. I’ve also tried moving the Anker hub to different ports in the dell hub, but the issue continues to persist.
Output of lsusb - tv:
/: Bus 001.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/5p, 480M
ID 1d6b:0002 Linux Foundation 2.0 root hub
|__ Port 001: Dev 002, If 0, Class=Billboard, Driver=[none], 12M
ID 32ac:0002
|__ Port 001: Dev 002, If 1, Class=Human Interface Device, Driver=usbhid, 12M
ID 32ac:0002
|__ Port 002: Dev 003, If 0, Class=Hub, Driver=hub/4p, 480M
ID 05e3:0610 Genesys Logic, Inc. Hub
|__ Port 003: Dev 004, If 0, Class=Hub, Driver=hub/3p, 480M
|__ Port 004: Dev 005, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 001: Dev 007, If 0, Class=Vendor Specific Class, Driver=[none], 12M
ID 27c6:609c Shenzhen Goodix Technology Co.,Ltd.
|__ Port 003: Dev 008, If 0, Class=Human Interface Device, Driver=usbhid, 12M
ID 32ac:0012
|__ Port 003: Dev 008, If 1, Class=Human Interface Device, Driver=usbhid, 12M
ID 32ac:0012
|__ Port 003: Dev 008, If 2, Class=Human Interface Device, Driver=usbhid, 12M
ID 32ac:0012
|__ Port 003: Dev 008, If 3, Class=Human Interface Device, Driver=usbhid, 12M
ID 32ac:0012
|__ Port 005: Dev 006, If 0, Class=Wireless, Driver=btusb, 480M
ID 0e8d:e616 MediaTek Inc.
|__ Port 005: Dev 006, If 1, Class=Wireless, Driver=btusb, 480M
|__ Port 005: Dev 006, If 2, Class=Wireless, Driver=[none], 480M
/: Bus 002.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/2p, 10000M
ID 1d6b:0003 Linux Foundation 3.0 root hub
|__ Port 002: Dev 002, If 0, Class=Hub, Driver=hub/3p, 10000M
ID 05e3:0625 Genesys Logic, Inc.
/: Bus 003.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/1p, 480M
/: Bus 004.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/1p, 10000M
/: Bus 005.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/1p, 480M
|__ Port 001: Dev 002, If 0, Class=Hub, Driver=hub/5p, 480M
ID 0bda:5487 Realtek Semiconductor Corp.
|__ Port 003: Dev 089, If 0, Class=Hub, Driver=hub/6p, 480M
ID 0bda:5413 Realtek Semiconductor Corp.
|__ Port 002: Dev 091, If 0, Class=Hub, Driver=hub/4p, 480M
ID 2109:2811 VIA Labs, Inc. Hub
|__ Port 001: Dev 093, If 0, Class=Audio, Driver=snd-usb-audio, 12M
ID 0d8c:0005 C-Media Electronics, Inc. Blue Snowball
|__ Port 001: Dev 093, If 1, Class=Audio, Driver=snd-usb-audio, 12M
|__ Port 001: Dev 093, If 2, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 002: Dev 101, If 0, Class=Audio, Driver=snd-usb-audio, 480M
ID 046d:082c Logitech, Inc. HD Webcam C615
|__ Port 002: Dev 101, If 1, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 002: Dev 101, If 2, Class=Video, Driver=uvcvideo, 480M
|__ Port 002: Dev 101, If 3, Class=Video, Driver=uvcvideo, 480M
|__ Port 003: Dev 092, If 0, Class=Hub, Driver=hub/5p, 480M
ID 0bda:5411 Realtek Semiconductor Corp. RTS5411 Hub
|__ Port 001: Dev 095, If 0, Class=Audio, Driver=snd-usb-audio, 12M
ID 041e:3249 Creative Technology, Ltd
|__ Port 001: Dev 095, If 1, Class=Audio, Driver=snd-usb-audio, 12M
|__ Port 001: Dev 095, If 2, Class=Audio, Driver=snd-usb-audio, 12M
|__ Port 001: Dev 095, If 3, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 002: Dev 096, If 0, Class=Human Interface Device, Driver=usbhid, 12M
ID 2dc8:301c 8BitDo
|__ Port 003: Dev 097, If 0, Class=Human Interface Device, Driver=usbhid, 12M
ID 1532:00b4 Razer USA, Ltd
|__ Port 003: Dev 097, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 003: Dev 097, If 2, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 004: Dev 098, If 0, Class=Human Interface Device, Driver=usbhid, 12M
ID 3434:d030
|__ Port 004: Dev 098, If 1, Class=Human Interface Device, Driver=usbhid, 12M
ID 3434:d030
|__ Port 004: Dev 098, If 2, Class=Human Interface Device, Driver=usbhid, 12M
ID 3434:d030
|__ Port 005: Dev 094, If 0, Class=Human Interface Device, Driver=usbhid, 480M
ID 413c:b06f Dell Computer Corp.
|__ Port 005: Dev 090, If 0, Class=Human Interface Device, Driver=usbhid, 480M
ID 413c:b06e Dell Computer Corp.
/: Bus 006.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/1p, 10000M
|__ Port 001: Dev 002, If 0, Class=Hub, Driver=hub/4p, 10000M
ID 0bda:0487 Realtek Semiconductor Corp.
|__ Port 003: Dev 003, If 0, Class=Hub, Driver=hub/4p, 5000M
ID 0bda:0413 Realtek Semiconductor Corp.
|__ Port 002: Dev 005, If 0, Class=Hub, Driver=hub/4p, 5000M
ID 2109:8110 VIA Labs, Inc. Hub
|__ Port 003: Dev 006, If 0, Class=Hub, Driver=hub/4p, 5000M
ID 0bda:0411 Realtek Semiconductor Corp. Hub
|__ Port 004: Dev 004, If 0, Class=Vendor Specific Class, Driver=r8152, 5000M
ID 0bda:8153 Realtek Semiconductor Corp. RTL8153 Gigabit Ethernet Adapter
/: Bus 007.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/1p, 480M
/: Bus 008.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/1p, 10000M
