Hi everyone,
I’m writing this because I’m incredibly frustrated and, frankly, disappointed with my experience with the Framework 16 and the RX 7700S module so far. I’m hoping for some advice or to see if others have faced similar hardware failures.
The Issue:
I realized quickly that the dGPU cannot be used properly for gaming without a 240W power supply. This wasn’t immediately clear to me during the purchase process. Since the official Framework 240W charger has a long lead time (Q2), I looked for alternatives based on community reports.
I purchased a Ugreen 500W charger (which features a dedicated 240W port). It arrived today, but after only 2 minutes of use, the power LED on the laptop disappeared. Now, the USB-C ports 1+2 on my Framework 16 are no longer working. I’ve tested them with other devices, and they seem completely dead.
My Frustrations:
Stability: For a laptop at this price point, I expected much better stability and clearer communication regarding power requirements for the dGPU.
Compatibility: It’s frustrating that the official charger is unavailable for months, forcing users to look for third-party solutions that seemingly risk frying the mainboard.
Efficiency: Seeing how unstable the power draw is, it feels like the current x86 implementation for this modular setup isn’t where it needs to be for gamers.
The Dilemma:
I likely need to contact support for a RMA, but I don’t have a spare device, so being without this laptop would be a disaster for my daily work.
Has anyone else experienced port failure when using high-wattage PD 3.1 chargers? Is there any “soft reset” for the ports/controller I should try before sending it back?
Thanks for any help.
