Manjaro sway bluetooth no default controller
Manjaro Sway
Which release version?
latest
Which kernel are you using?
I tried 6.3.17, 6.12.10, 6.11.9 (on 6.11.9 after restart bluetooth start working but then system freezed and I had to reboot it - then it stopped working again)
Also 6.12.19 linux-lts
probably latest
Which Framework Laptop 16 model are you using?
AMD Ryzen 9 7940HS w/ Radeon 780M Graphics
So the problem is that I can’t access bluetooth controller, bluetoothctl just says that there is no controllers at all
rfkill list
0: hci0: Bluetooth
	Soft blocked: no
	Hard blocked: no
1: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: no
systemctl status bluetooth
● bluetooth.service - Bluetooth service
     Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
     Active: active (running) since Sat 2025-03-22 22:41:07 +04; 1s ago
 Invocation: caade77cf5314987bf8f79dce2836c2c
       Docs: man:bluetoothd(8)
   Main PID: 8446 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 37473)
     Memory: 652K (peak: 2.2M)
        CPU: 23ms
     CGroup: /system.slice/bluetooth.service
             └─8446 /usr/lib/bluetooth/bluetoothdMar 22 22:41:07 dkeysil-fw systemd[1]: Starting Bluetooth service...
Mar 22 22:41:07 dkeysil-fw bluetoothd[8446]: Bluetooth daemon 5.80
Mar 22 22:41:07 dkeysil-fw systemd[1]: Started Bluetooth service.
Mar 22 22:41:07 dkeysil-fw bluetoothd[8446]: Starting SDP server
Mar 22 22:41:07 dkeysil-fw bluetoothd[8446]: Bluetooth management interface 1.23 initialized
sudo dmesg | grep Bluetooth
[   13.031898] Bluetooth: Core ver 2.22
[   13.031938] Bluetooth: HCI device and connection manager initialized
[   13.031946] Bluetooth: HCI socket layer initialized
[   13.031950] Bluetooth: L2CAP socket layer initialized
[   13.031955] Bluetooth: SCO socket layer initialized
[   13.176541] Bluetooth: hci0: Failed to get device id (-108)
[   13.176551] Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
[   13.436828] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   13.436832] Bluetooth: BNEP filters: protocol multicast
[   13.436836] Bluetooth: BNEP socket layer initializedlsmod | grep btusb
btusb                  81920  0
btrtl                  32768  1 btusb
btintel                69632  1 btusb
btbcm                  24576  1 btusb
btmtk                  32768  1 btusb
bluetooth            1097728  15 btrtl,btmtk,btintel,btbcm,bnep,btusb
The strangest part is Bluetooth: hci0: Failed to get device id (-108) but I wasn’t able to find a solution in google
update: I reconnected Wi-Fi module and it started working. For 2 days.
Then laptop just freezed once again and after restart - no default controller for bluetooth.
Feels like something is wrong with hardware, like it’s glitching because of the voltage or something.
I tried to reconnect Wi-Fi module once again but it didn’t work out.
I’m running into the same issue on Arch Linux with my Framework Desktop.
Have you been able to work around the issue @Dmitry_Kisel?
Edit: A simple reboot fixed this.
Ran into the same issue on my Arch. BT did work but after a kernel update, it stopped working. I though this might work better with an officially supported distro so I move to Fedora. After install, BT worked but after a system update, I’m now back to no bluetooth working :joy:
Guess I can move back to my trusted Arch again, knowing that bluetooth doesn’t work on Fedora either…
