I just installed my Framework 13 with Windows, and as it’s a replacement for a Dell XPS 13 7390, I’m comparing the two as they sit next to each other.
I’m running speedtest.net and nperf.com from the same room, on the same access point (but not at the same time), on the same network.
The dell gets usually double the download speed.
I changed servers a bunch of times, but it’s always the same: it’s getting 125Mbps whereas the Killer AX1650w of the Dell is getting 275-300Mbps
Is this a known thing about this Mediatek network adapter being so slow?
Just adding another data point from my Framework 13 with the RZ616 card. Running Windows 11, sitting in the same chair with my Pixel 6 Pro getting 100+Mbps. When I put the machine together and installed the framework driver package, my laptop was getting no more than half the download speed of my other devices. Installing the same 3.3.0.908 driver above Instantly bumped it from ~20Mbps down to ~95Mbps. Seems to be rock solid now!
I just found out it is an issue with the signal strength from my router.
I tested the speeds in my lounge room and then went to the room where the router is and ran the test right next to the router and the download speed went from 48Mbps in the lounge room to 842Mbps next to the router.
