Mellanox MCX631102AN-ADAT adapter card
Will the new Framework Desktop PC accommodate a Mellanox MCX631102AN-ADAT adapter card?
Or can you recommend a substitute card with a single 10GBps SFP port that will fit inside the Framework Desktop PC?
NVIDIA ConnectX-6 Lx PCIe HHHL Ethernet Adapter Cards User Manual
No, the card you linked requires 8 PCIe lanes, but the Framework desktop mainboard only has a 4 lane slot. Also the Framework Desktop case is too small to fit any PCIe card, you’d need to use a larger Mini-ITX case like the NZXT H210 and buy the Framework Desktop mainboard alone.
Excellent. Thanks for the feedback!
