Microphone stopped working, camera still works
Which Linux distro are you using? Arch + KDE
Last date updated? April
Which kernel are you using? 6.14.4-arch1-1
Which BIOS version are you using? 03.05
Which Framework Laptop 13 model are you using? 12th Gen Intel® Core™
Hi! I’ve recently been having issues with my microphone, namely that it’s not working at all. At first I thought it was because it had gone bad, so I bought and installed a new camera/microphone, but the microphone still isn’t detected.
lsusb:
Bus 003 Device 002: ID 32ac:0002 Framework HDMI Expansion Card
Bus 003 Device 003: ID 046d:c542 Logitech, Inc. M185 compact wireless mouse
Bus 003 Device 004: ID 32ac:001c Framework Laptop Webcam Module (2nd Gen)
Bus 003 Device 005: ID 27c6:609c Shenzhen Goodix Technology Co.,Ltd. Goodix USB2.0 MISC
Bus 003 Device 006: ID 8087:0032 Intel Corp. AX210 Bluetooth
It’s detecting the webcam module, but pactl list sources only has the internal monitor.
Any ideas? Thanks!
I tested it on Fedora 41 on a liveusb, and it worked there.
I also ran a diff between Fedora’s lsusb -v and Arch’s lsusb -v and there wasn’t a significant difference for the camera module. This was the only difference (which I’m assuming isn’t applicable):
+        VideoControl Endpoint Descriptor:
+          bLength                 5
+          bDescriptorType        37
+          bDescriptorSubtype      3 (EP_INTERRUPT)
+          wMaxTransferSize       32
Well I feel extraordinarily dumb… I had the device mode in “Analog Stereo Output” mode instead of “Analog Stereo Duplux”. Kinda confused why it would be duplex since I thought the microphone was over USB, not the intel driver, but oh well…
Reasonable expectation, I think. But no, just the camera is usb.
Did you ever figure out anything further about this? I think I’m in a similar situation, with a 12th gen Framework 13 that has never given me audio difficulties before (running up-to-date Arch Linux with Pipewire and the pipewire-pulse compatibility module). I last used the microphone in April with no issues. Just tried it this morning and the built-in (webcam) microphone wasn’t available to most applications under the default pavucontrol profiles.
When I switch to the “Pro Audio” profile, the microphone works as expected, but I don’t get any playback through the speakers or analog headphone jack. So, I basically have to choose between input or output.
I had been using the sof-firmware package to enable audio over HDMI per HDMI audio output? - #21 by WERRY_Brice; using that firmware inhibits the normal “Analog Stereo Duplex” profile. I commented out the “options snd-intel-dspcfg dsp_driver=3” from my /etc/modprobe.d and rebooted to restore the duplex profile option, and now I can again have analog input & output, but no audio over HDMI. I’m convinced there’s no underlying hardware issue (since all of those components work fine in separate configurations) and suspect that a recent (last ~2 months) auto-installed update to some layer of the sound system changed the device detection (most suspiciously, the “Unplugged” annotation on the microphone in the default profile when using sof-firmware).
If anyone else has gotten any further in troubleshooting this, I’d love to hear what you learned.
Interesting… These are the options when I connect to a TV over HDMI (KDE):
I have both Digital Stereo (HDMI) Output + Analog Stereo Input and Analog Stereo Duplex in my options. Not exactly helpful, but it’s surprising I can’t reproduce the issue.
EDIT: I should clarify that I haven’t had to change anything with modprobe to get this to work.
