Mystery FW16 7940HS - BIOS codes and blinkies
I just got a mystery box that included an FW16 7940HS motherboard with a wanged-up heatpipe. I’m throwing this out there to see if anyone else has encountered these error codes or has an idea for a next thing to try. I’d love to get this board booted and running headless.
Test: Basic power
Bare board connected to 65W charger, power button pressed. USB-PD meter says it draws 10W, red/blue lights alternate. So far so good.
Test: Partial testbench
1 SODIMM installed in board, connected to display + power/fingerprint of known-good FW16. ~60 seconds of red/blue alternating LEDs, then diagnostic lights in the following pattern:
WRGGGGRRRGGGGOBGGBBGGG
After some searching, I found these resources for decoding the lights. My understanding is that the FW13 11th gen diagnostic LED guide should be more-or-less accurate for any Framework laptop, and that the Port80/Insyde BIOS codes are based on public information but not customized to the laptop.
Putting it together:
Blink Description Comment
White Start of diagnosis
Red Battery connected check Correct. Blocks boot?
Green Power Good 3V5V supply Good
Green Power Good VCCIN_AUX Good
Green CPU deassert sleep S4 Good
Green Power boot core VR Good
Red Input module fault Correct. Blocks boot?
Red No left fan Correct. Blocks boot?
Red No right fan Correct. Blocks boot?
Green GPU module OK Correct, in the sense that there’s no GPU module to have a fault
Green CPU reached S0 state Good
Green DDR initialized OK Good
Green Internal display initialized OK Good
Then POST code is 001 1001 or 0x19. That’s
#define BDS_CONNECT_USB_HC 0x19 // USB host controller initial
Anyone seen POST code 0x19 before and know what it implies about the USB controller? I don’t think it’s just the lack of input modules - when I was reassembling my complete FW16, I left out the input board plug and the screen lit up to tell me about the problem. But that might be related to the BIOS version.
I don’t know what BIOS version is installed on the mystery board, and I don’t know what options are set in the BIOS. If I reset to defaults, will the standalone mode work?
Is the best bet to test functionality to completely install the mystery board in a shell? Is there an alternative?
