Need help running signal-desktop in distrobox
Using Fedora 41 workstation on 6.11.4-301.fc41.x86_64 with 7040 Framework 13.
The Flatpak version of Signal gives a warning about storing stuff in plaintext. So I wanted to use distrobox to run the officially supported version. I created a 24.04 Ubuntu container with distrobox and followed the instructions on Signal >> Download Signal. But when I try to run it, I get this error:
signal-desktop: symbol lookup error: signal-desktop: undefined symbol: snd_device_name_get_hint, version ALSA_0.9
Can anyone help me with getting it to work or additional troubleshooting? I haven’t been able to get anywhere with google searching the error message.
Ah, I got it. The answer was to install libasound2, which for the 24.04 ubuntu container ended up being
sudo apt install libasound2t64
I can confirm, that works :slight_smile:
But there’s also a Flatpak. All-tough that gives a warning about not being encrypted on your computer.
