Has anybody successfully gotten their DP monitor to work with their laptop on Fedora 34 (under Wayland)?
What I’ve Tried
Monitor plugged directly into Framework DP Module. Result:
lsusbshows the adapter - monitor detects cable is plugged in, but not getting signal, goes to sleep
- OS doesnt see 2nd monitor
Monitor plugged into Dell WD15
- Monitor detects cable, no signal, goes to sleep
- OS shows 2nd monitor, thinks its sending a signal
HDMI both via my Framework HDMI Module and via the WD15 work with no issues.
Happy to post outputs/logs as appropriate.
