I think, this is what actually is happening here, due to the entire expression being evaluated as a part of hardware.firmware.
You can confirm that it works by checking what version of VCN has been loaded, e.g., by sudo dmesg | grep "Found VCN". Without the override, I am currently getting version 1.10:
[ 1.902575] [drm] Found VCN firmware Version ENC: 1.10 DEC: 5 VEP: 0 Revision: 0
with, I get version 1.17, Rev. 10, as expected:
[ 1.896711] [drm] Found VCN firmware Version ENC: 1.17 DEC: 6 VEP: 0 Revision: 10
Like I mentioned, this turned out to be easier to implement on NixOS than I expected⦠But, if it doesnāt work for you, please let me know.
I had the similar/same issues (white screen on full screen and then on on all screens), along with wifi issues (wifi would randomly disconnect and would not reconnect like the process crapped out, tried to use restart network manager a few hundred times over a few weeks to no avail).
Best temp fix I found was to downgrade to a lower kernel version.
No issues with suspend or waking on the stable kernel but I did have issues with the latest kernel and it wasnāt just white flashing screen sometimes programs would act strangely where I though I had bad ram but several ram test showed no errors.
Does this by any chance also affect stable? I just upgraded my packages which included a bump of the linux kernel from 6.6.13 to 6.6.14 and that build wonāt boot:
Jan 31 14:42:41 nixos kernel: amdgpu 0000:c1:00.0: Direct firmware load for amdgpu/psp_13_0_4_toc.bin failed with error -2
Jan 31 14:42:41 nixos kernel: [drm:amdgpu_device_init [amdgpu]] *ERROR* early_init of IP block <psp> failed -19
Jan 31 14:42:41 nixos kernel: amdgpu 0000:c1:00.0: amdgpu: Fatal error during GPU init
As a result, xserver crashes with āno screens foundā and ends up in a restart-loop.
Edit: False alarm, even downgrading to 6.6.13 didnāt fix that. Had to go back to the previous generation!
I have ordered the an AMD framework to upgrade from my 11th gen intel and was just wondering if anything in the configs needs to be changed for it to boot. I know thereās the extra potions to get things (e.g., finger print) working, but is there anything to do with the hardware-config file?
I feel like since Iām changing the hardware, Iāll need to boot into a nixos iso to generate a new hardware-config file. Can anyone confirm if thatās the case?
I usually do this regardless and then just a quick eyeball-diff my current config to the generated one. Mostly to get the architecture specific kernel/boot parameters/modules right.
If you are not cherry-picking firmware and just have all redistributable enabled (or have linux-firmware in the list), then it should boot just fine. I donāt know about intel, but I donāt have anything particularly AMD-specific in my config, i.e. default settings + linux-firmware/redistributable boots without any issues.
After it boots, youāll want to add AMD-specific fixes, like kernel args for the white screen thing and other gpu/power related tweaks. (You can also prebuild your AMD config while on Intel and have it in your bootloader menu ready to go.)
Thank you for the help! I think the only thing Intel specific I have is the kvm module. It just feels like the hardware configuration should be updated with changing the mainboard even though it mainly relates to the storage and filesystem.
