Someone drilled some holes temperatures from all sensors drop and the fan speed dropped 45%. If you know how to adjust TDP the FL12 may be capable of 25W sustained
The input cover has a protective barrier on the underside of the keyboard pcb, so it’s sealed tight. The way the bottom cover is designed and molded, the only way any air is being drawn in by the fan is via the intake in the rear.
Edit: There’s a very slight gap between the sheet metal backing of the keyboard and the input cover, so I’m sure there’s some air being drawn in through there, but it would have to be next to nothing. I’m guessing there’s also a silicone membrane sheet under the keys, so no air is going to be flowing between the keys.
I suspect the reason they didnt drill holes (or realistically, add a grill) there is because of discomfort (when being used on a lap) and also that when you flip it over as a tablet, it would cover the entire intake.
So they have to route the air to have a path alternative to just “hole on the bottom plate”
The screen seems to block the vent holes a lot too if it’s folded in the right places.
I’ve always hated vent holes on the bottom because, yeah, then you block them with your lap; these ones are close enough to the bottom that my legs sometimes block them or my pants as well.
I’m sure some air comes in through the USB holes and other gaps… but I’m glad to hear people saying the new Core motherboard is going to run cooler. I’ve got my $100 deposit in for a motherboard now.
I just have the standard chill pad, under for now with the i3.
These modifications are a great idea though, thanks.
