How Should I Use Cool Down The Laptop Using Fans?
My previous Laptops had hot air exhaust on the bottom of the laptop. My understanding is that this one has it going up toward the screen down in the hinge area of the frame. So, my question is should I have air blowing into the base of the frame or extracting it away?
I have no problem with it passive. Do you intend to run it at full load for a while, in which case I would think into the bottom :slight_smile:
