Noise fans playing with rx 7700 s and cpu. Doubt powerbank
But does it have an accessible user environment? Can you control the tdp?
And the developer is very grateful for the work he does.
But this should be done by the framework team or at least help the developer.
@Ekkehard_F Thanks for the link
The current version has a bug. If you roll back one version - it should run.
I don’t use windows except for VERY rare cases - and in most cases, its on my VM… So I cant validate the steps - only share what I have seen from users who are using it.
From the link:
just recycled old version from recycle bin did install and its working ok , seems like something wrong with latest version , pls check , its good that its not merged yet
Can you please cite sources for this:
Most brands have this and it is a job that the framework should do.
I owned a Lenovo Legion 7 slim. Fans, frequencies, and TDP could not be adjusted. There was NO workaround.
HP Omen:
**Thermal design power** (**TDP**) is not configurable as per HP Standards, the same is system managed and tweaking it using 3rd party software is neither recommended or supported by HP, as its designed to work on it's optimal performance as per design.
XMG - I can find no proof that TDP can be configured
MSI - not without a flashed bios…
This is what I have found with my research. And for AMD chips older than the one in the FW16, the recommendation has been to use Ryzen Master for CPU frequencies and TDP if the chip itself supports it. Not to use 1st party software by any of the above.
