Noisy clicking Touchpad
Hello Together,
yesterday my DIY Laptop arrived and all in all im very happy with it. I think i had luck with the hinges. My are performing very well by now.
But one thing that annoys me a bit is the touchpad. It looks like it has some tolerances. So when using is it don’t feel very good, because everytime you make a left click (soft) with just tabbing and not pressing the touchpad it make a clicking sound. Is this normal to other users too?
I have an other short question. Is there an option via Key-Combination to shut down the monitor? On my previous Laptop (acer) there was an “fn” combination for that. Its helpful in some situations to save some battery time.
LG Benjamin
The touchpad shouldn’t be moving when you tap it without physically clicking it. Try contacting support about this.
If you’re on Windows, here’s a script that will turn your display off:
powershell (Add-Type '[DllImport(\"user32.dll\")]^public static extern int PostMessage(int hWnd, int hMsg, int wParam, int lParam);' -Name a -Pas)::PostMessage(-1,0x0112,0xF170,2)
You can then invoke it via keyboard shortcut using PowerToys or AutoHotkey.
Hello,
I think I have a problem with my touchpad.
It’s as if there is a "gap/clearance’’ between “layers” of touchpad.
It makes some noise before “real” click, and it happens just by laying your finger at the bottom of touchpad.
Thanks in advance
PS: Sorry for my bad english
First of all, no need to apologize for your English, even if it were bad (which it isn’t). I have the same problem, however I only notice it when the device is laying flat on a surface. Since I mostly use it on my lap in bed, I can live with that.
When I asked the support about it and sent them a video, they asked me to follow this guide. Didn’t fix it for me, but maybe you have better luck. If you search this forum, you’ll see that we’re not the only ones having this problem, maybe it’s standard behaviour for the touchpad.
For now I’ll probably wait until there’s a touchpad upgrade option, as I’m not a fan of the physical click. A Macbook really spoils you in that regard.
Hello Jason and Alexis,
good to know that i`m not the only one. I also contacted the support a while ago and got the same repair guide, which was’nt helpful for me. I also send a video and tried to explain what the problem is to the support. But they didn’t really understand it. After a while and because this issue isn’t this big, only annoying i gave up and live with it.
But thanks for your reply. It gives me a little hope, that they will work on a better touchpad in the future.
I had the same issue. I solved it by putting a piece of paper between the touchpad and the chassis. Its enough that the touchpad has no wiggle room and prevents the clicky sound while tapping on the touchpad. It doesnt interfere with normal clicking:
Hello,
I just tried to use the guide but didn’t change anything for me.
I think it’s a “design problem” and @Jan-Eric_Schafrich shows us the right solution. (but I hope for a real fix from Framework)
I will try to contact the support.
i have the same issue and i’m just going to put a small piece of electrical tape on the flanges
I too have/had this problem my replacement input cover was definitely an improvement so if it is bad check with support.
The solution I chose is similar to stated above however I taped the length of the left and right edges of the touchpad restricting the movement/rattle and stopping debris falling down the crack over time.
Guys,
I have a batch 6 laptop. And it has been doing great since I got it. However for the last few months, it developed the sticky touchpad. The issue was that every so often, the trackpad would not depress and register a right click.
Well I finally got around to emailing support, who determined that I needed to replace the entire input cover, so they sent me another one and I swapped it out. The new one appears physically identical.
However, while it does work reliably, I have to say that I hate it. It is making a chirping sound on each tablet depress. Imagine a very quiet cricket noise. It sounds as if it is a mechanical sound. I think the problem is that they are relying on physical depression of the trackpad assembly to register clicks. It is the physical chirping which is the real killer.
I will use an external mouse for now, but my advice is to go back to the drawing board. Find the guys who actually make the Dell XPS or MacBook touchpads and use them. Right now, the touchpad has similar travel to a key on the keyboard. I am going to try the paper trick and see of that helps.
Did it end up making a difference?
hey @Jan-Eric_Schafrich, thanks a lot! I had the same problem, and putting paper as you described fixed the issue.
CC @Blueprint
Sorry if this has been answered already.
I think this is due to inactivity but my touchpad makes a higher pitched clicking sound after I release it in addition to the standard releasing sound. Haven’t opened it up to look at anything yet in case it’s something I can do without opening.
@Jan-Eric_Schafrich thanks for the idea. I put some electrical tape on the flanges and the trackpad is rock solid now. This was driving me crazy.
I got mine in February and it has the same problem.
@Jan-Eric_Schafrich thank you.
