My situation: I bought a 13", 13th gen intel and got it about 2 weeks ago. I didn’t have time to do anything with it, other than 1 full charge, until yesterday. When I started it for the first time, after I installed Ubuntu 24.04, I saw that the battery had only 97.5% capacity. (Btw, I set the max charging to 80% in the UEFI, after that first one-time full charge.)
How can there be already such a degradation? Is this a case for customer support?
There is fluctuation in all batteries, and the readings you get from a single full charge cycle are not going to be incredibly accurate. A few power cycles in should give you a more realistic situation. Understand too that not all batteries are going to be exactly the same. They are built to be within spec, and not exactly identical. (Nature of the chemistry and manufacturing process, etc.)
Thanks, got it.
Would it be better then to do several full charge cycles before switching to 80% max?
Yes, I think it would be, but that is just based on my experience.
I’m really enjoying looking through your link! Thanks for sharing!
Thanks for this. I read around a bit and will do two cycles of full charge and full empty. Then switch to 80% charge and not lower than 20% – that’s what I’m doing with my mobile devices too. Same type of battery, so I suppose same “training.” ![]()
