[not sure if it's fixed, but it might be] Bluetooth constantly searching for other devices and I can't stop it
Linux Mint 22.2
Kernel 6.14
BIOS 4.02
AMD Ryzen™ 7040 Series
I use bluetooth quite regularly with Sony WF1000XM3s and I only noticed today that my bluetooth constantly looks for other bluetooth devices and will not let me stop. This persists even when doing
sudo systemctl restart bluetooth.service
or
sudo systemctl stop bluetooth.service
and
sudo systemctl start bluetooth.service
This also eventually starts to happen again after I reboot.
This has never happened before.
Does anyone know what’s going on and how to fix it?
Also, turning off the bluetooth applet or exiting also doesn’t work
Here’s the logs from Gnome Logs. Does it help?
12:48:42 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-61 noise=9999 txrate=960700
12:48:42 systemd: systemd-rfkill.service: Deactivated successfully.
12:48:41 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-60 noise=9999 txrate=960700
12:48:41 systemd-logind: Watching system buttons on /dev/input/event22 (REVVL 6x PRO 5G (AVRCP))
12:48:41 boltd: probing: timeout, done: [2001523] (2000000)
12:48:41 kernel: input: REVVL 6x PRO 5G (AVRCP) as /devices/virtual/input/input40
12:48:40 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-59 noise=9999 txrate=1200900
12:48:39 dbus-daemon: [system] Connection “:1.93” is not allowed to add more match rules (increase limits in configuration file if required; max_match_rules_per_connection=2048)
12:48:39 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=1200900
12:48:39 boltd: probing: started [1000]
12:48:38 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-59 noise=9999 txrate=1200900
12:48:38 dbus-daemon: [system] Connection “:1.93” is not allowed to add more match rules (increase limits in configuration file if required; max_match_rules_per_connection=2048)
12:48:37 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-61 noise=9999 txrate=1200900
12:48:37 dbus-daemon: [system] Connection “:1.93” is not allowed to add more match rules (increase limits in configuration file if required; max_match_rules_per_connection=2048)
12:48:37 NetworkManager: [1772221717.7518] device (EC:35:4D:1C:53:F5): state change: unavailable → disconnected (reason ‘none’, sys-iface-state: ‘managed’)
12:48:37 kernel: Bluetooth: hci0: AOSP quality report is supported
12:48:37 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-59 noise=9999 txrate=1200900
12:48:37 kernel: Bluetooth: hci0: HW/SW Version: 0x008a008a, Build Time: 20250523103438
12:48:37 systemd: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
12:48:37 dbus-daemon: [system] Successfully activated service ‘org.blueman.Mechanism’
12:48:37 systemd: Starting blueman-mechanism.service - Bluetooth management mechanism…
12:48:37 dbus-daemon: [system] Activating via systemd: service name=‘org.blueman.Mechanism’ unit=‘blueman-mechanism.service’ requested by ‘:1.93’ (uid=1000 pid=2786 comm=“/usr/bin/python3 /usr/bin/blueman-applet” label=“unconfined”)
12:48:36 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-59 noise=9999 txrate=1200900
12:47:16 rtkit-daemon: Supervising 12 threads of 9 processes of 1 users.
12:47:16 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=1200900
12:47:09 rtkit-daemon: Supervising 12 threads of 9 processes of 1 users.
12:47:09 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-57 noise=9999 txrate=1200900
12:47:06 rtkit-daemon: Supervising 12 threads of 9 processes of 1 users.
12:47:06 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-59 noise=9999 txrate=1200900
12:47:01 systemd: Started blueman-manager.service - Bluetooth Manager.
12:47:01 dbus-daemon: [session uid=1000 pid=1875] Successfully activated service ‘org.blueman.Manager’
12:47:01 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-59 noise=9999 txrate=1200900
12:47:01 systemd: Starting blueman-manager.service - Bluetooth Manager…
12:47:01 dbus-daemon: [session uid=1000 pid=1875] Activating via systemd: service name=‘org.blueman.Manager’ unit=‘blueman-manager.service’ requested by ‘:1.81’ (uid=1000 pid=2786 comm=“/usr/bin/python3 /usr/bin/blueman-applet” label=“unconfined”)
12:47:01 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-62 noise=9999 txrate=960700
12:46:41 systemd-resolve: Using degraded feature set TCP instead of UDP for DNS server 172.30.110.10.
12:46:41 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-62 noise=9999 txrate=1080600
12:46:16 systemd: blueman-mechanism.service: Deactivated successfully.
12:46:16 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=1200900
12:45:52 systemd: systemd-rfkill.service: Deactivated successfully.
12:45:52 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=1200900
12:45:48 systemd: blueman-manager.service: Consumed 37.128s CPU time.
12:45:48 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-59 noise=9999 txrate=1200900
12:45:47 systemd: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
12:45:47 NetworkManager: [1772221547.1192] device (EC:35:4D:1C:53:F5): state change: disconnected → unmanaged (reason ‘removed’, sys-iface-state: ‘removed’)
12:45:47 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-61 noise=9999 txrate=1200900
12:45:46 dbus-daemon: [system] Rejected send message, 0 matched rules; type=“method_return”, sender=“:1.62” (uid=1000 pid=1866 comm=“/usr/bin/wireplumber” label=“unconfined”) interface=“(unset)” member=“(unset)” error name=“(unset)” requested_reply=“0” destination=“:1.9” (uid=0 pid=951 comm=“/usr/libexec/bluetooth/bluetoothd” label=“unconfined”)
12:45:46 bluetoothd: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free unit: getpeername: Transport endpoint is not connected (107)
12:45:46 systemd: Started blueman-mechanism.service - Bluetooth management mechanism.
12:45:46 dbus-daemon: [system] Successfully activated service ‘org.blueman.Mechanism’
12:45:46 systemd: Starting blueman-mechanism.service - Bluetooth management mechanism…
12:45:46 dbus-daemon: [system] Activating via systemd: service name=‘org.blueman.Mechanism’ unit=‘blueman-mechanism.service’ requested by ‘:1.93’ (uid=1000 pid=2786 comm=“/usr/bin/python3 /usr/bin/blueman-applet” label=“unconfined”)
12:45:45 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-59 noise=9999 txrate=1200900
12:45:43 dbus-daemon: [system] Connection “:1.93” is not allowed to add more match rules (increase limits in configuration file if required; max_match_rules_per_connection=2048)
12:45:42 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-59 noise=9999 txrate=1200900
12:45:42 systemd-resolve: Using degraded feature set UDP instead of TCP for DNS server 172.30.110.10.
12:45:42 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-61 noise=9999 txrate=1200900
12:45:40 bluetoothd: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
12:45:40 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-61 noise=9999 txrate=1200900
12:45:32 bluetoothd: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
12:45:31 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-59 noise=9999 txrate=1080600
12:45:22 dbus-daemon: [system] Connection “:1.93” is not allowed to add more match rules (increase limits in configuration file if required; max_match_rules_per_connection=2048)
12:45:21 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=1200900
12:45:21 dbus-daemon: [system] Connection “:1.93” is not allowed to add more match rules (increase limits in configuration file if required; max_match_rules_per_connection=2048)
12:45:18 dbus-daemon: [system] Connection “:1.93” is not allowed to add more match rules (increase limits in configuration file if required; max_match_rules_per_connection=2048)
12:45:16 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=1200900
12:45:16 dbus-daemon: [system] Connection “:1.93” is not allowed to add more match rules (increase limits in configuration file if required; max_match_rules_per_connection=2048)
12:45:13 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-57 noise=9999 txrate=1200900
12:45:11 dbus-daemon: [system] Connection “:1.93” is not allowed to add more match rules (increase limits in configuration file if required; max_match_rules_per_connection=2048)
12:45:10 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=1200900
12:45:09 dbus-daemon: [system] Connection “:1.93” is not allowed to add more match rules (increase limits in configuration file if required; max_match_rules_per_connection=2048)
12:45:07 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=1200900
12:45:04 dbus-daemon: [system] Connection “:1.93” is not allowed to add more match rules (increase limits in configuration file if required; max_match_rules_per_connection=2048)
12:45:03 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=1200900
12:45:02 rtkit-daemon: Supervising 12 threads of 9 processes of 1 users.
12:45:00 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=960700
12:44:32 bluetoothd: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
12:44:32 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=1080600
12:44:28 rtkit-daemon: Supervising 12 threads of 9 processes of 1 users.
12:44:28 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=1080600
12:44:11 systemd: blueman-mechanism.service: Deactivated successfully.
12:44:11 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-61 noise=9999 txrate=1200900
12:44:09 dbus-daemon: [system] Connection “:1.93” is not allowed to add more match rules (increase limits in configuration file if required; max_match_rules_per_connection=2048)
12:44:09 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-61 noise=9999 txrate=960700
12:44:06 rtkit-daemon: Supervising 12 threads of 9 processes of 1 users.
12:44:06 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-60 noise=9999 txrate=1080600
12:44:06 dbus-daemon: [system] Connection “:1.93” is not allowed to add more match rules (increase limits in configuration file if required; max_match_rules_per_connection=2048)
12:44:05 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-54 noise=9999 txrate=1080600
12:44:02 dbus-daemon: [system] Connection “:1.93” is not allowed to add more match rules (increase limits in configuration file if required; max_match_rules_per_connection=2048)
12:44:02 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=1200900
12:44:01 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=1080600
12:44:01 dbus-daemon: [system] Connection “:1.93” is not allowed to add more match rules (increase limits in configuration file if required; max_match_rules_per_connection=2048)
12:44:01 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-61 noise=9999 txrate=1080600
12:44:00 dbus-daemon: [system] Connection “:1.93” is not allowed to add more match rules (increase limits in configuration file if required; max_match_rules_per_connection=2048)
12:44:00 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-61 noise=9999 txrate=1080600
12:43:59 dbus-daemon: [system] Connection “:1.93” is not allowed to add more match rules (increase limits in configuration file if required; max_match_rules_per_connection=2048)
12:43:59 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=1080600
12:43:59 rtkit-daemon: Supervising 12 threads of 9 processes of 1 users.
12:43:59 bluetoothd: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
12:43:59 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-59 noise=9999 txrate=1080600
12:43:51 dbus-daemon: [system] Connection “:1.93” is not allowed to add more match rules (increase limits in configuration file if required; max_match_rules_per_connection=2048)
12:43:51 bluetoothd: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
12:43:51 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-59 noise=9999 txrate=960700
12:43:47 systemd: systemd-rfkill.service: Deactivated successfully.
12:43:47 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-59 noise=9999 txrate=960700
12:43:47 dbus-daemon: [system] Connection “:1.93” is not allowed to add more match rules (increase limits in configuration file if required; max_match_rules_per_connection=2048)
12:43:46 systemd-logind: Watching system buttons on /dev/input/event22 (REVVL 6x PRO 5G (AVRCP))
12:43:46 kernel: input: REVVL 6x PRO 5G (AVRCP) as /devices/virtual/input/input39
12:43:46 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-59 noise=9999 txrate=960700
12:43:45 boltd: probing: timeout, done: [2002151] (2000000)
12:43:45 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-59 noise=9999 txrate=960700
12:43:43 boltd: probing: started [1000]
12:43:43 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-62 noise=9999 txrate=960700
12:43:43 NetworkManager: [1772221423.2071] device (EC:35:4D:1C:53:F5): state change: unavailable → disconnected (reason ‘none’, sys-iface-state: ‘managed’)
12:43:43 kernel: Bluetooth: hci0: AOSP quality report is supported
12:43:43 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-59 noise=9999 txrate=960700
12:43:43 kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
12:43:42 systemd: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
12:43:42 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-59 noise=9999 txrate=960700
12:43:37 sudo: pam_unix(sudo:session): session closed for user root
12:43:37 systemd: Started blueman-mechanism.service - Bluetooth management mechanism.
12:43:37 sudo: pam_unix(sudo:session): session opened for user root(uid=0) by ryker(uid=1000)
12:43:37 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=1200900
12:42:39 systemd: blueman-mechanism.service: Deactivated successfully.
12:42:39 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-57 noise=9999 txrate=1080600
12:42:19 systemd-resolve: Using degraded feature set TCP instead of UDP for DNS server 172.30.110.10.
12:42:17 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=960700
12:42:14 systemd: systemd-rfkill.service: Deactivated successfully.
12:42:14 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=960700
12:42:09 rtkit-daemon: Supervising 12 threads of 9 processes of 1 users.
12:42:09 systemd: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
12:42:09 NetworkManager: [1772221329.5874] device (EC:35:4D:1C:53:F5): state change: disconnected → unmanaged (reason ‘removed’, sys-iface-state: ‘removed’)
12:42:09 systemd: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status…
12:42:09 dbus-daemon: [system] Rejected send message, 0 matched rules; type=“method_return”, sender=“:1.62” (uid=1000 pid=1866 comm=“/usr/bin/wireplumber” label=“unconfined”) interface=“(unset)” member=“(unset)” error name=“(unset)” requested_reply=“0” destination=“:1.9” (uid=0 pid=951 comm=“/usr/libexec/bluetooth/bluetoothd” label=“unconfined”)
12:42:09 bluetoothd: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free unit: getpeername: Transport endpoint is not connected (107)
12:42:09 systemd: Started blueman-mechanism.service - Bluetooth management mechanism.
12:42:09 dbus-daemon: [system] Successfully activated service ‘org.blueman.Mechanism’
12:42:09 systemd: Starting blueman-mechanism.service - Bluetooth management mechanism…
12:42:09 dbus-daemon: [system] Activating via systemd: service name=‘org.blueman.Mechanism’ unit=‘blueman-mechanism.service’ requested by ‘:1.93’ (uid=1000 pid=2786 comm=“/usr/bin/python3 /usr/bin/blueman-applet” label=“unconfined”)
12:42:08 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-61 noise=9999 txrate=960700
12:42:07 dbus-daemon: [system] Connection “:1.93” is not allowed to add more match rules (increase limits in configuration file if required; max_match_rules_per_connection=2048)
12:42:07 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=960700
12:42:06 rtkit-daemon: Supervising 12 threads of 9 processes of 1 users.
12:42:06 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-59 noise=9999 txrate=960700
12:41:59 dbus-daemon: [system] Connection “:1.93” is not allowed to add more match rules (increase limits in configuration file if required; max_match_rules_per_connection=2048)
12:41:59 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=960700
12:41:53 dbus-daemon: [system] Connection “:1.93” is not allowed to add more match rules (increase limits in configuration file if required; max_match_rules_per_connection=2048)
12:41:53 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=1200900
12:41:40 bluetoothd: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
12:41:40 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-60 noise=9999 txrate=1200900
12:41:32 bluetoothd: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
12:41:31 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=1200900
12:41:27 dbus-daemon: [system] Connection “:1.93” is not allowed to add more match rules (increase limits in configuration file if required; max_match_rules_per_connection=2048)
12:41:26 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-59 noise=9999 txrate=1200900
12:41:23 dbus-daemon: [system] Connection “:1.93” is not allowed to add more match rules (increase limits in configuration file if required; max_match_rules_per_connection=2048)
12:41:22 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-61 noise=9999 txrate=1080600
12:41:21 rtkit-daemon: Supervising 12 threads of 9 processes of 1 users.
12:41:19 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-62 noise=9999 txrate=1080600
12:40:42 dbus-daemon: [system] Connection “:1.93” is not allowed to add more match rules (increase limits in configuration file if required; max_match_rules_per_connection=2048)
12:40:41 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=1080600
12:40:40 bluetoothd: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
12:40:38 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-60 noise=9999 txrate=1080600
12:40:32 bluetoothd: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
12:40:32 dbus-daemon: [system] Connection “:1.93” is not allowed to add more match rules (increase limits in configuration file if required; max_match_rules_per_connection=2048)
12:40:32 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=1080600
12:40:28 rtkit-daemon: Supervising 12 threads of 9 processes of 1 users.
12:40:28 firefox-bin: ATTENTION: default value of option mesa_glthread overridden by environment.
12:40:26 rtkit-daemon: Supervising 12 threads of 9 processes of 1 users.
12:40:26 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-61 noise=9999 txrate=1200900
12:40:23 rtkit-daemon: Supervising 12 threads of 9 processes of 1 users.
12:40:23 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-62 noise=9999 txrate=1080600
12:40:15 dbus-daemon: [system] Connection “:1.93” is not allowed to add more match rules (increase limits in configuration file if required; max_match_rules_per_connection=2048)
12:40:15 wpa_supplicant: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-63 noise=9999 txrate=960700
While I was trying to figure this out, the battery percentage also broke. I am completely lost. I’m going to use system timeshift to revert to a known working version of my OS
Now, the battery works again and I got this:
Module libgcc_s.so.1 from deb gcc-14-14.2.0-4ubuntu2~24.04.1.amd64
Module libstdc++.so.6 from deb gcc-14-14.2.0-4ubuntu2~24.04.1.amd64
Module libzstd.so.1 from deb libzstd-1.5.5+dfsg2-2build1.1.amd64
Module libsystemd.so.0 from deb systemd-255.4-1ubuntu8.12.amd64
Module libudev.so.1 from deb systemd-255.4-1ubuntu8.12.amd64
Stack trace of thread 1382:
#0 0x00007036d049eb2c __pthread_kill_implementation (libc.so.6 + 0x9eb2c)
#1 0x00007036d044527e __GI_raise (libc.so.6 + 0x4527e)
#2 0x00007036d04288ff __GI_abort (libc.so.6 + 0x288ff)
#3 0x00005c3cef63cfae OsAbort (Xorg + 0x1e4fae)
#4 0x00005c3cef642af7 n/a (Xorg + 0x1eaaf7)
#5 0x00005c3cef643b77 FatalError (Xorg + 0x1ebb77)
#6 0x00005c3cef63a12b n/a (Xorg + 0x1e212b)
#7 0x00007036d0445330 __restore_rt (libc.so.6 + 0x45330)
#8 0x00007036d049eb2c __pthread_kill_implementation (libc.so.6 + 0x9eb2c)
#9 0x00007036d044527e __GI_raise (libc.so.6 + 0x4527e)
#10 0x00007036d04288ff __GI_abort (libc.so.6 + 0x288ff)
#11 0x00007036d042881b __assert_fail_base (libc.so.6 + 0x2881b)
#12 0x00007036d043b517 __assert_fail (libc.so.6 + 0x3b517)
#13 0x00005c3cef4dc444 dixRegisterPrivateKey (Xorg + 0x84444)
#14 0x00007036cfb8970b glamor_init (libglamoregl.so + 0xb70b)
#15 0x00007036cfbda648 n/a (modesetting_drv.so + 0x14648)
#16 0x00007036cfbd035f n/a (modesetting_drv.so + 0xa35f)
#17 0x00005c3cef4baf10 AddGPUScreen (Xorg + 0x62f10)
#18 0x00005c3cef51a8f0 n/a (Xorg + 0xc28f0)
#19 0x00005c3cef5209f8 n/a (Xorg + 0xc89f8)
#20 0x00005c3cef51cc62 n/a (Xorg + 0xc4c62)
#21 0x00005c3cef51d240 n/a (Xorg + 0xc5240)
#22 0x00005c3cef63ab9a n/a (Xorg + 0x1e2b9a)
#23 0x00005c3cef6334f5 WaitForSomething (Xorg + 0x1db4f5)
#24 0x00005c3cef4ba86a n/a (Xorg + 0x6286a)
#25 0x00005c3cef4beeda n/a (Xorg + 0x66eda)
#26 0x00007036d042a1ca __libc_start_call_main (libc.so.6 + 0x2a1ca)
#27 0x00007036d042a28b __libc_start_main_impl (libc.so.6 + 0x2a28b)
#28 0x00005c3cef4a7395 _start (Xorg + 0x4f395)
Stack trace of thread 1702:
#0 0x00007036d0498d71 __futex_abstimed_wait_common64 (libc.so.6 + 0x98d71)
#1 0x00007036d049b7ed __pthread_cond_wait_common (libc.so.6 + 0x9b7ed)
#2 0x00007036cd399edd n/a (libgallium-25.2.8-0ubuntu0.24.04.1.so + 0x599edd)
#3 0x00007036cd365fbb n/a (libgallium-25.2.8-0ubuntu0.24.04.1.so + 0x565fbb)
#4 0x00007036cd399e0c n/a (libgallium-25.2.8-0ubuntu0.24.04.1.so + 0x599e0c)
#5 0x00007036d049caa4 start_thread (libc.so.6 + 0x9caa4)
#6 0x00007036d0529c6c __clone3 (libc.so.6 + 0x129c6c)
Stack trace of thread 1445:
#0 0x00007036d052a072 epoll_wait (libc.so.6 + 0x12a072)
#1 0x00005c3cef63ab50 n/a (Xorg + 0x1e2b50)
#2 0x00005c3cef638059 n/a (Xorg + 0x1e0059)
#3 0x00007036d049caa4 start_thread (libc.so.6 + 0x9caa4)
#4 0x00007036d0529c6c __clone3 (libc.so.6 + 0x129c6c)
Stack trace of thread 1710:
Stack trace of thread 1707:
Stack trace of thread 1711:
Stack trace of thread 1712:
Stack trace of thread 1716:
Stack trace of thread 1714:
Stack trace of thread 1706:
Stack trace of thread 1715:
Stack trace of thread 1708:
ELF object binary architecture: AMD x86-64
Bluetooth is currently not trying to connect to everything, so I’m going to do a restore point now so I can revert back to this working state. I think it may be some system updates causing this. I’m not sure. I’m really tempted to distro hop to Ubuntu
Upon closer look into what I updated, the only thing that I updated was the Mullvad Browser Alpha, Heroic Games Launcher, and RSS Guard. I have no idea what went wrong. I finished the backup and am going to wait a while before I try to update anything. I would like someone to reply before I mark this as fixed so that if there’s something still wrong at least someone has my back I guess
So, it’s back to immediately trying to connect to everything again. This was never an issue before today and I have been using the exact same setup and haven’t installed anything or updated anything beyond what I said earlier. What is going on?
I closed Microsoft Edge and it fixed the bluetooth issue…
How does that even happen? Like the second it opens when bluetooth is running, the bluetooth breaks, but as soon as it closes, it works again! WTH Microsoft?!
I double and triple checked this. It will only break if MS Edge is open. Why?
I can’t tell if that’s just a coinsidence, but it hasn’t been breaking as of the last 20 minutes, so I guess it has to me MS Edge
Now, it seems to work when Edge is going only when there is only 1 instance of it. I am still confused and need answers
Sounds to me like it might be quicker to do a rebuild rather than troubleshooting.
I ran Linux Mint 22.2 and then 22.3 on my FW16 for a while and recently moved to Fedora Workstation. I’m finding Fedora better performing and more reliable… all round a much improved Linux experience.
