Nice, that’s what i wanted to hear.
In the preview of the Swedish keyboard I notice that some basic labels are missing:
- Apostrophe (level 1) — on the
2key - Quotation mark (level 2) — on the
*key
Is this an artefact of the image or will these labels also be missing on the yet-to-be released keyboards?
Image: https://static.frame.work/872g7limumy2bdljnapulu0d0a3h
Bought Overkill 16! yay, been waiting a LONG time for this, my current Laptop is in rags!
Though only with the ISO blank keyboard, but I guess it’s a good way to upgrade later and to make a truly custom PC!
as a beginner question, can the expansion bay be swapped at will? (guessing not while turned on) but let’s say before a business travel to the light one?
#DanishFramework!
crying in Icelandic
Any details on when we can expect to order a prebuilt framework 13 with Danish keyboard?
Hej Anton, I think you can do that today? (As far as I know it is only the 16 danish keybord that is not out)
(Edit: at least preOrder)
You can pick it on DIY edition but the prebuilts are much more limited when it comes to keyboard selections.
Sorry about that, I was talking about the 16" keyboard. The 13" version in the marketplace has the correct labels. The Danish layout is missing the apostrophe label on the 13", but is correct on the 16"… I’m not understanding the logic here; is this an oversight that is going to be fixed (or already has been fixed) in a future revision or is it by design?
Personally, I’m typing by touch, so I would be fine and could go with blank keys. It may seem superficial to some of you, but as the laptop sometimes will be used by others (not as comfortable with touch typing), missing apostrophe and quotation mark labels has made me reconsider buying.
SE/FI (16"): https://frame.work/se/en/products/keyboard-module?v=FRAKDW00AS
SE/FI (13"): https://frame.work/se/en/products/input-cover-kit?v=FRANHC000S
Hey Kess, we had some issues with the images on the marketplace (Not the actual layout, double checked with the teams to confirm) and our team fixed the images last Thursday, can you please check and confirm if you still see this issue? Thanks!
Thank you Destroya for checking,
I removed all cached content from my browser and checked again, the images are mostly the same.
Guided selection:
- (The 13" selection guide has no previews, so cannot check Danish here)
- The 16" Swedish/Finnish keyboard is still missing the labels in the preview image
product: https://frame.work/se/en/products/laptop16-diy-amd-7040/configuration/new
image: https://static.frame.work/872g7limumy2bdljnapulu0d0a3h
Marketplace:
- The 13" Danish keyboard is still missing the apostrophe/single quotes on the key between
ØandEnter
product: https://frame.work/se/en/products/input-cover-kit?v=FRANHC000V
image: https://static.frame.work/d9017hacjwrlvwt193fit5x9pwxo - The 16" Swedish/Finnish keyboard now has double quotes on the
2key (yay!) but is still missing the apostrophe/single quotes on the key betweenÄandEnter
product: https://frame.work/se/en/products/keyboard-module?v=FRAKDW00AS
image: https://static.frame.work/j0woiz3quxo8veixm2glsozbq1nd
Thanks Kess, I’ll share this with the team!
I did get replies pretty quickly initially, but when the ticket was moved to something called the “Framework Escalation support”, I haven’t heard anything back. The ticket was escalated on 1st of July and now it has been more than ten days without any replies. Does it usually take this long or should I do something more on my end? ![]()
Thanks for letting me know, I’ll escalate this internally.
Hope to see them available in Norway soon.
Amen!
Great news - as it’s slow and steady approaching my country!
First of all: I very much appreciate the efforts put in to the entire Framework-project. Now, I’m in need of purchasing a laptop as my current is breaking down (been on life support a couple of years waiting for Framework availability), and was really hoping to avoid buying a replacement-solution until the Framework becomes available in my country.
Are there any ETA on when it will be possible to purchase from Norway?
A post was merged into an existing topic: [Shipping] Asia / Taiwan / Singapore orders
Piling on to the crowd that is eagerly awaiting Norwegian availability.
