Null expansion card
In my expected use of the 16" laptop I’ve ordered it will spend a fair bit of time at my desk plugged into my Ethernet, but it would be nice to leave that protruding card at home when I take it elsewhere, however that will leave a big gap in the bottom of the laptop. I could get an extra USB card to fill the gap, but don’t really need any more. Could you make a simple cover, or null expansion card, to slot into the space to fill the gap? Will everyone need 6 functional expansion cards?
Makes sense but for $9 probably makes sense to just populate the unused slots with another USBC pass thru.
Or one where you could store snacks? The SNACK Drawer V2: Back in Snacktion
I would go for a network to USB-C adapter or a small usb dock and not change the expansion card at all. The expansion cards are simple X->USB-C adapters after all, so there is no advantage of the expansion card to external adapters if you don’t plan to carry them with you laptop
You could also use the 3D model files Framework has available to print your own spacer card to go in the space. If you don’t own a 3D printer yourself there are online services that will 3D print things for you.
