Final Test “Report” on OCuLink 8i with Framework 16 (AMD Ryzen 7 7840HS / RTX 3090)
Hi all, I did more testing with a total of 10 AAA titles of the last 5 years, all in maximum settings or close to maximum settings, and compared both OCuLink 4i with 8i. Here is my “final report” of my experience regarding performance and also troubleshooting for anyone interested.
Does it work?
Yes, once you figure out how to set it up, it does work well and in a stable way with the board of @Filip . And yes, the tech is real, and it does result in a performance increase.
In my testing, I have seen about half of the games that did only show a minor improvement of about 2%, close to margin of error. About one additional third of the games showed noticeable improvements of around 5%. And a few games showed significant gains of 10% or even slightly above. So yes, OCuLink 8i is real, it is an improvement in games. Overall, across all testing I have done, I would say you can expect on average a performance increase of 5%. I also confirm that the bandwidth I measured is close to twice that of 4i, so for other use cases than gaming this may also be significant (perhaps even more).
Is it worth it?
I would say yes. Given the time of current costs of hardware, 5% performance increase for the cost of a cheap Aliexpress EGPU plus the board is a good way to go. However, it is pretty game specific, varies a lot. Perhaps the reason is that some are more CPU heavy, while others depend more on the GPU. Another argument in favour of 8i is that it provides you with 5% increase of base frames. For those using AI tools such as frame gen, you can multiply the gains accordingly ;).
How do I get it to work?
So once you know what to do it is pretty straightforward. You can order the Aliexpress EGPU plus the cable on Aliexpress, you get the board from @Filip and plug it together. If you have a GPU that requires a PSU, don’t forget to turn on the power switch in the EGPU. Once the hardware is set up, you turn on the EGPU, then the notebook. If nothing happens and you do not see the GPU in device manager, run the error 43 fixer. If this does not work, then change the script in the .bat file of the error 43 fixer. If this is also not sufficient, go to your BIOS, press F9, and then F10, to reset the BIOS to “optimal default” settings. Finally, if this is still not enough, you can do a battery disconnect in the BIOS, save it, wait 2 minutes, and then turn on the notebook and EGPU again (after replugging the power cable). That should do it. I also checked out all these steps in 2 different BIOS versions, 3.07 and 4.03, both work fine.
It was a fun experience and is an amazing step forward for the Framework 16 community that the board exists. Thank you again to @filip for allowing me to test it. I will also definitely get the final “product” from him once we have it.
