Ok everyone, I got Filip’s board in and was able to get it to work on my AI 370. It definitely works and shows the difference between 4i and 8i both in GPU-Z Bus Interface and AIDA64 data speeds respectively. I will try and keep this as short as possible as images make it quite large.
GPU-Z 4i:
GPU-Z 8i:
**To FWPL’s point, this seems to be a very game specific variance as I tested a few games. Some did slightly better, some did worse.**
For starters, everything was done on the exact same version of Windows 11 Pro 25H2 with the AI 370 Mainboard, 32GB of RAM, Power Mode: Best Performance, using AMD 9070 XT with Adrenalin 26.1.1 @ 2560 x 1440 on a 27inch external Samsung monitor with a 165hz refresh rate. All games were at ultra settings and had all frame gen turned off (Adrenalin had it turned off too). The only thing active (if available for the game) was FSR 4 upscale.
~Red Dead Redemption 2: (Better)
This game is the only one I had on hand with a built in benchmark at present.
4i Benchmark:
Minimum: 15.6114 FPS
Maximum: 158.798 FPS
Average: 121.089 FPS
4i In Game:
Lowest: 100 FPS
Average: 112 FPS
Peak: 118 FPS
8i Benchmark:
Minimum: 15.193 FPS
Maximum: 164.872 FPS
Average: 125.086 FPS
8i In Game:
Lowest: 102 FPS
Average: 114 FPS
Peak: 120 FPS
~The First Descendant: (Better)
4i In Game:
Lowest: 63 FPS
Average: 77 FPS
Peak: 81 FPS
8i In Game:
Lowest: 65 FPS
Average: 84 FPS
Peak: 91 FPS
~Escape From Tarkov: (Worse)
4i In Game:
Lowest: 109 FPS
Average: 114 FPS
Peak: 144 FPS
8i In Game:
Lowest: 76 FPS
Average: 98 FPS
Peak: 110 FPS
~Starfield: (Better)
4i In Game:
Lowest: 74 FPS
Average: 77 FPS
Peak: 81 FPS
8i In Game:
Lowest: 74 FPS
Average: 80 FPS
Peak: 86 FPS
~3DMark: (Worse/Better Respectively)
4i Steel Nomad:
Score: 6986 / 69.86 FPS
8i Steel Nomad:
Score: 6918 / 69.18 FPS
4i Time Spy:
Score: 26829
Test 1: 177.96
Test 2: 151.49
8i Time Spy:
Score: 26965
Test 1: 180.32
Test 2: 151.22
I know it was a short list, and these were all down and dirty as soon as I got the board working and run in the same order from 4i to the 8i swap. I am not a tech expert, so I don’t have the answers as to why this stuff is showing some worse data. What I can definitely say though is my GPU was able to actually reach 99-100% utilization on the 8i board whereas it was never able to do that on the 4i. Averaged high 80% with 4i. You’d think it would mean more of a difference, but not as drastically as it would seem. More GPU utilization, the less bottle-necking occurring, which is definitely a plus side on the 8i factor as twice the lanes are being utilized therefore more headroom.
Final Thoughts:
-Does it work? Yes, it certainly does. On now confirmed both the Framework 7X40 series and 300 series.
-Is it WORTH it? Your mileage may vary. If you do not have the 4i variant, 8i may be for you as it cost about the same for the 8i, just not as nice a set up as the DEG1 (AliExpress version is bare bones board). Me personally? No, not compared to getting the DEG1 for the 4i with KyleTuck’s adapter and then spending additional for the AliExpress Board and cable. As others have said on other forums and numbers prove in this thread, the gains are only roughly 3-5% whereas it seems some are loss (this could be a potential handshake issue somewhere).
I would like to say in closing, I did this to see for myself the potential of 8i (and to help a fellow developer), and while the gains do not seem to be anything drastic, I do want to applaud @Filip for creating (to my knowledge) the first successful 8i board for the Framework Laptop. It was a great privilege to be a part of the testing community and get to share with you all. Maybe as time progresses, I can find additional tweaks to see if there are differences in performance, but for now this is my review.
