Or Framework 13 12th Gen Intel i7-1280P sometimes running slow - suggestions for fixing the 400 MHz bug
Purpose of this post
After 2 years, I realised that I too was suffering from the 400 MHz bug, where my Framework’s CPUs would seemingly randomly throttle at 400 MHz. If you don’t know what I’m talking about, just search “400 MHz” on this forum.
I’m sure there are other posts from people who didn’t realise what was happening and who, like me, were being driven up the wall trying to figure out why their laptop was slowing down randomly.
The posts on this forum were only partially helpful. From speaking with Framework support, I was able to find a better solution, namely removing the HDMI expansion card. I couldn’t find this information anywhere, and so I’m writing it down here for others to find.
TL;DR
To fix the issue:
  • Remove expansion cards, in particular HDMI or Display Port
  • Reset the embedded controller by holding down the power button for 30 seconds or so
Bug characteristics
  • Laptop inexplicably slows down, sometimes for a couple of seconds or sometimes endlessly. It feels like you’re using a computer from 10-20 years ago and tasks such as music / video editing, gaming, etc are impossible.
  • Very difficult to reproduce, it really just seems random
  • Restarting seems to have no or just a temporary effect
Confirming that it’s the 400 MHz bug
When your laptop slows down, check the CPU frequency. If it’s stuck at 400MHz, then it’s probably this.
If you’re on Linux, you can type:
watch -n.1 "grep \"^[c]pu MHz\" /proc/cpuinfo"
Suggestions for fixing it
Removing problematic expansion cards
I got this information from Framework support:
The 400MHz lock is also caused by a signal called BD PROCHOT (Bi-Directional Processor Hot). This signal allows other components (such as a wonky power adapter or a sensor) to tell the CPU to throttle, even if the CPU temperature is low.
A loose or faulty Expansion Card (especially HDMI or DisplayPort) can leak current and confuse the EC. Try running the laptop with all cards removed to see if the spikes vanish.
Removing my HDMI expansion card fixed the problem for me.
Resetting the mainboard’s embedded controller
This may or may not help. It didn’t for me, but it seems to have for others, see e.g. here
In a first instance, try just turning off your laptop by holding the power button, remove the charger, wait a couple of minutes, then boot up again.
If that doesn’t work, then a more thorough process (as suggested by Framework support) is:
  • Turn off the laptop and unplug the charger
  • Remove all expansion cards and the Input Cover.
  • Then, disconnect or remove only the RAM, the SSD, the RTC coin, and the battery cable (no need to remove the entire battery).
  • Leave the removed components for 15 minutes.
  • Reinstall or reinsert the RAM, the SSD, and the battery cable.
  • Plug the laptop into the charger.
Reapplying thermal paste
Some people e.g. here found that this fixes the issue, but as this person points out, it’s probably because in the process the embedded controller is reset.
Other fixes
If all else fails:
Intel Extreme Tuning Utility (Windows)
Framework support suggested:
using msr-tools to disable the PROCHOT bit, though this is more advanced.
I think this is Linux specific and above my abilities.
My gripes with Framework support
In general, I had a very good experience with support. They got back to me within hours and were able to suggest removing the expansion card which fixed my issue. So for that, cheers!
However, I doubt that it would have been such a quick fix if I hadn’t self diagnosed the 400 MHz issue. I would have personally appreciated foregoing all the usual niceties of “what’s your BIOS, did you use a dock, what power adapter are you using, …” given that this seems to be such a frequent problem. Or at the very least, asking me those questions but also suggesting it to me right from the start.
What I would really want is for Framework to write about this in the knowledge base. I really do not understand why it’s not there. What’s more, I asked Framework support when I was in contact with them 3 separate times if they could either share more information online (e.g. in the knowledge base) or explain to me why they hadn’t done so yet. This bug is not new. The earliest reference I could find of it in the forums was from Framework themselves back in 2021. This bug has been driving me absolutely nuts - I’ve spent 2 years dealing with it intermittently and was only able to fix it during an artistic residency this week where it was so bad that I couldn’t make music at all and I was able to I spend 2 days figuring out what was going on.
Anyway, in the meantime I hope that this helps.
Wow. Great post. It is a shame this is still occurring and there is nothing formal in the Framework knowledge base about it with steps to mitigate it. @Quin_Chou @nrp @Framework
If it does come to loose or faulty expansion cards, though, is that something Framework replaces for free if still under warranty?
I guess the issue there could be either with the expansion card or with the connection on the mainboard itself (so either expansion card replacement or mainboard replacement).
I guess the only way to narrow it down would be:
  1. Reset the EC as you outlined
  2. Run laptop as normal without the HDMI and/or DP expansion card in place for a while
  3. Shut down laptop
  4. Insert the HDMI and/or DP expansion card in a different port to the one it was in originally when causing the issue
  5. Power on laptop and use as normal and check to see if bug occurs.
  6. If it does - replace the expansion card and run the test again.
  7. If bug occurs with replacement expansion card - possible need to replace the mainboard
  8. If bug occurs with the replacement mainboard and replacement expansion cards (essentially a new laptop at that point) then the issue is much deeper.
I really wanted that to be the solution. Dumb/hilarious/pathetic that this would be the cause, but if it would’ve freed me from this 400mhz prison, i’d have launched this card into orbit. The 400mhz bug is so widespread that i’m 99% sure someone would’ve made the connection already if it was a fix.
3 minute stress test in HWInfo, stopped as soon as it hit 400mhz. Still not recovered 20 minutes later as I write this from my desktop, despite temps dropping to normal levels :
Not solved.
We need a solution @nrp .
I am hammering on two machines with 1260p boards. One from a mystery box occasionally freezes (maybe that’s why it was in the mystery box in the first place) while the other keeps on cranking. Is there a trick to triggerinng the issue? I tried setting to max performance in the bios, then after the mystery box board froze up a couple of times - not every time - I switched that to max battery in the bios and it has not frozen or triggered the issue since. These are non-critical machines so I am happy to beat on them if it could be of any use. They’re both on the latest bios. One is running cachyos, the other fedora. 16gb ram (2x8gb) and an off-brand (BiWin) 2tb ssd in the the cachyos machine, 32gb ram (2x16gb) and an off-brand (Inland Pro) 2TB ssd. Both 2x usb-c, 2x usb-a.
  • Found this thread
  • Picked up my FW13
  • unhibernated it (because it dumps 60%+ battery overnight in sleep, gave up fighting for that one)
  • took out my hdmi card
  • rebooted to give it the best chance of forgetting about that card
  • ran hwinfo stress test until it throttled (as I said, around 3 minutes, you can see the 6 minute uptime on my task manager)
  • stopped the stress test
  • took the screenshot of the clock speed
  • made the previous post
Simple as that. You seem to downplay my issues over the many times i’ve posted about it, but it’s really that bad. It’s literally unusable.
I saw the post and grabbed the machines to try to help if I was able to reproduce it. I don’t doubt that you’re hitting the issue. I don’t know if it is something that impacts certain cpus in the generation, certain memory configurations, ssds, et cetera. I assume that it is hardware-specific rather than OS-specific.
I’m not the least bit interested in arguing with you. I can try to help you and others if there’s any chance of discovering any new information about what triggers this. But in order to do so I need a bit more than “sh*t’s broke!” - OS, CPU, SSD, RAM, cards, CPU settings in BIOS and in OS, and so on. Maybe that information is contained throughout the forum, but I am sorry, I am not going to go chasing after it.
I have machines that I can try to use to reproduce the issue. I am willing to do so. But I need a bit more than “run stress test.” I did that. I couldn’t reproduce it. That DOES NOT mean that the issue does not exist. It DOES mean that either it’s a hardware edge case that the boards that I have are not susceptible to, or some parameter(s) of the test ddi not match.
Well it’s clearly my board that is this bad. I also don’t want to type out again the 100s of steps i’ve already taken over again.
There’s also no value in you trying to reproduce it. We know there are boards out there it doesn’t affect, it has no bearing on what my board does.
It’s 100% clear that my particular board is borked and i’ve provided evidence over and over. My warranty ran out while I was waiting for promised BIOS updates. Others had their boards replaced, even out of warranty.
I am not letting them leave me on the hook for this.
It might be worth looking at Smokeless UMAF.
There was another post somewhere on here that someone found a timeout setting. The normal bios setting has it set to timeout never.
If they set it to a sensible value, the cpu would then exit its throttle state.
I cannot remember the throttle timeout setting, but worth a look.
Isn’t that an AMD tool? Their issue with the 400MHz is with an Intel CPU.
My suspicion: they know it’s a design failure and they’re attempting to avoid a class-action lawsuit. If they openly acknowledge it they admit liability before a case even gets started.
I don’t disagree, but I wonder if a customer could start a guide on the topic. I appreciate it’s not an effort that a customer should have to go to, but such is the nature of complex ecosystems - sometimes it is just more practicable to do something oneself.
One might still need to ask Support for edit permissions on the wiki, but I assume that FW would grant that to a kind volunteer.
FYI, a FW employee responds to the Knowledge Base suggestion here:
Coming back here to say that the issue is back. It’s not as bad as it used to be, but producing music is becoming frustrating again, and even the fix of removing all HMDI adapters does not necessarily fix it. I’ll probably just buy a new board at some point and keep this one for cutting bread on out of spite.
I guess you are why we needed to stop putting lead in solder XD
Cut the wire responsible for triggering PROCHOT_EXT signal
Orrr… Disable BD Prochot. I’ve read elsewhere that you shouldn’t do this probably, but at this point I don’t care, I want a useable laptop, even if this comes back to bite me in the arse in the future. If you don’t hear from me, assume this worked out
EDIT: Aaaaaaaaaand no, doesn’t work, the EC flipcs BD_PROCHOT back on immediately, an issue that’s logged on that Github script (Ctrl + F “Write succeeds but the value reads back unchanged”)
Also for what it’s worth I have the latest BIOS, 3.20 (command for checking it is: sudo dmidecode -t bios)
I got Brave AI to get me a solution that just keeps disabling BD_PROCHOT really fast, but that doesn’t work either, probably because the EC resets itself really fast (every millisecond or so). The throttled daemon that’s linked in the Github script also doesn’t work
Framework, if you’re reading this, I would really like to see any sort of hack patch that would fix this, because I really, really do not want to shell out 600 euros or so on a new motherboard and also I don’t want to create e-waste
Because why would it?
FW failed at implementing Intel’s CPU effectively.
So I made some progress. I realised that the throttling was occuring only when I was charging my laptop, so it seems that this is what is now sending the faulty BD_PROCHOT signal to the EC. If I charge my laptop without the expansion cards, i.e. I plug in directly to the recessed USB-C ports on the motherboard, then I don’t seem to have any issues.
So next step is to buy some new usb C expansion cards and see if this fixes the problem. It seems that you can also buy 3rd party ones, which I might do just as a :fu: to Framework (see below).
As an aside, Framework support was less helpful this time. They suggested I do a bunch of things that were quite some effort (e.g. checking if it was a faulty RAM slot that was causing the issue) while ignoring the information that I was giving them about the charger. They then told me I had a faulty motherboard and that since I was out of warranty I was on my own. Not cool Framework :angry:
A story as old as time.
I think it’s wishful thinking on your part, I very much doubt new expansion cards will do a single thing.
I throttle on battery and charge.
