Discourse forum supports passkeys for authentication. We should enable that in this forum:
If passkeys are available, they should definitely be enabled. Much better than usernames and passwords, by far.
The version of discourse used by the forum should support it. But isn’t the login common to both forum and the main framework website? We don’t login with the discourse modal but we are redirected to the main domain.
Thanks for the suggestion, we will check this internally with the team.
