Physical aspect ratio of 2256x1504 display?
Hi, List of common display resolutions - Wikipedia claims that Framework’s original/matte 2256x1504 display has a physical aspect ratio of 8:5.
This combination of a logical (storage) 3:2 aspect ratio with a physical aspect ratio of 8:5 would mean that the display has non-square pixels (pixel aspect ratio = (8/5) / (3/2) = 1.067).
Is it true that the physical aspect ratio of the display is 8:5? What are the dimension of the active area of the display panel?
I’ve always understood that the physical aspect ratio was 3:2 (the same as the pixel ratio).
I’ll try to measure it ASAP.
Added later:
Phew. As near as I can measure, it is 285mm x 190mm. Exactly 3:2.
Added even later:
Search results seem pretty consistently to say the aspect ratio of the surface laptop is 3:2 too. I have corrected Wikipedia.
I’m starting to believe that that Wikipedia page has the wrong data.
According to [RESPONDED] AMD Framework minimum brightness too high (now with measurements), the current 13" panels are NE135GXM-N61. Panelook page for NE135GXM-N61 states
Active Area: 284.933(W)×189.955(H) mm
284.933 / 189.955 = 1.5 ⇒ 3:2 physical aspect ratio, not 8:5.
