Picking the Right Expansion Cards
I’m currently playing with the options for a FW12 laptop, but I’m finding myself a little stuck when picking expansion cards. I plan to use it primarily for HTML, CSS, and JS coding, plus some digital art on the side. My usual selection of cards is: 1x USB-C, 2x USB-A, 1x SD card. (I have a DSLR camera gathering dust that uses micro-SD, and I have an SD-to-micro SD adapter.) Since I’m not sure when I’d be able to pick up more expansion cards, does this setup sound ideal? Would a different card be more useful for an SD card, considering I don’t currently do much digital photography?
(If I put this in the wrong spot, please let me know. I’ll go to the appropriate forum and post there.)
Thanks much!
I went with the following cards.
Regularly used:
  • 4x USB-C (rarely use USB-A, preparing for the future)
  • 1x USB-A
Picked them up just in case… to save on future shipping:
  • 1x microSD (have not used regular SD size in more than a decade)
  • 1x HDMI
  • 1x DP
Also pre-ordered the desktop with almost all cards. When I bought my FW13 I only got 4 cards. Regretted that a lot as shipping would have been expensive.
This is what I have, but I wouldn’t use this as like a … Framework official recommendation or anything. Just what I personally use.
  • x2 USB-C (power and if I need to plug something else in like a mouse)
  • x1 USB-A (comes in handy when I need to install my OS onto testing equipment)
  • x1 Micro-sd (I go to events a lot so I can easily upload my photos/videos from my DSLR, but I also have one of those… multi-dongle things that connect via USB-A that include Micro-SD if I ever need it)
  • x1 HDMI (need…more….screens…….)
The rest I just casually swap if I need it such as SD or more USB-Cs honestly.
Thanks for the suggestions. I hadn’t thought about ordering extra cards with the FW12 to save on S&H later. Time to play with numbers and see what fits in the budget.
I won’t bore you with my selection; it won’t make sense for your use case since I’m sharing some expansion cards across my FW16 and FW12. Here’s what I would buy if I were in your place:
Bare minimum:
  • 3-4 USB-C
  • 1 HDMI if you will need it to access an external monitor without a docking station.
My logic here is that good HDMI-to-USB-C adapters can be pricey, but adapters for everything else you use is pretty cheap. USB-C will account for most of your usage in the long term. Additionally, you don’t want to be caught with a broken charging port and no replacement handy.
If you have the budget:
  • 3-4 USB-C
  • 1 USB-A
  • 1 SD card
  • 1 HDMI (if needed)
You’re right about the SD card being more versatile while you’re getting started with digital photography. An adapter can let you use a MicroSD card in an SD slot, but the reverse is not true. USB-A is becoming less and less commonly used. One is nice to have, but more than that isn’t that useful in the long term.
When I ordered my fw13, I got:
  • 4x usb c
  • 1x usb a
  • 1x hdmi
  • 1x dp
  • 1x microSD
  • 1x ethernet
When I ordered the fw12, i added:
  • 1x usb a
  • 2x usb c
Ultimately, I’ve been keeping 3x usb c and 1x usb a in each of them, and the hdmi, dp, sd, and ethernet are swapped in for one of the usb c when needed/desired. being able to share the specialty cards is a real bonus for me.
If we end up with another fw12 for my husband, I would probably go with 2x usb c, 1x usb a, and 1x hdmi for him, i think.
Personally, I’d get at least two USB-C, but that’s me. Since USB-C is used for charging and so many things are moving to USB-C these days, I find two C and one A more useful. But that will depend on how much USB-A stuff you have.
USB-C can also connect to docks, displays, etc. I find them far more versatile than USB-A.
I got 2 USB-Cs for hubs and charging. Then I got 2 USB-As because I have a lot of USB-A devices and cell phone chargers.
Display output and wired networking will be handled by the hubs, I like having a mostly symmetrical port layout in terms of general-purpose ports like USB, and I have a portable hub that I can plug in anywhere for more connectivity like HDMI and Ethernet, so this was the perfect configuration for me.
when I ordered my FW13, I got 3 USB-C and 3 USB-A, my sister got the same for hers a month or so later, my FW12, which hasn’t shipped yet, has 2 USB-C, 2 USB-A, an HDMI, and a display port.
I had originally planed to just use a USB hub for external monitors, should they be needed, but I found that the cheap hub I have will periodically lose connection, which means the screen basically has to reboot…manageable, but annoying.(I should also note, it has the same issues on my other laptops, this is not a framework problem)
as for layout, I run USB-C on both back ports, and USB-A on the front ports, I like being able to charge from either side, and most of the stuff I need to connect is older stuff that uses USB-A
I’d got two USB-C, so I can plug the charger into both sides, which is convenient as you don’t have to do weird cable routing depending on the location of yoru charger. I also got HDMI and SD-Card reader. I didn’t got any USB-A cards as I think these are outdated and I prefer to avoid them. (I have adapters if really needed)
I got:
  • 4 USB-C
  • 2 USB-A
  • 1 HDMI
  • 1 DisplayPort
  • 1 Ethernet
The plan is to always have 2 USB-C ports in the back slots, for charging from either side. I’ll swap in cards as needed into the front slots. Probably 2 USB-C, 1 USB-A, 1 HDMI as the “default” config.
Per-card reasoning …
4 USB-C cards because they’re versatile, and because they match the chassis color, so they’re a good filler if I don’t need a specific port.
2 USB-A ports so that I can copy things between USB drives or card readers. I’ve got already got a USB-A to SD/MicroSD card reader in my bag, so USB-A is also my “card reader” port.
HDMI will get some use with projectors and TVs and such.
DisplayPort because it’s the superior port and I wish the world would switch to it, even though it’ll probably only get used at home where I could just use a dock instead.
Ethernet is the least critical, since I already have a USB Ethernet adapter. But it’ll be more convenient if I need to plug directly into something (server? router? random network device?) to troubleshoot something where there isn’t a proper table. The card won’t tend to unplug like an adapter would. I’ll also use it when installing Linux so that I don’t have to mess with wifi.
Going with all USB-C (4x) in bubblegum to match the case. Considering HDMI later in case I want to hook up to a monitor/TV, or I might just get a dongle/adapter. Everything else I use nowadays is USB-C or I can easily find an adapter/alternative cable.
Honestly after a while I’ve settled on 4xUSB-C and plug in an HDMI/USB-A/charging adaptor when needed. The adaptor is a bit more flexible and keeps more ports free. And having a lot of USB-C ports is nice. Plus if you’re plugging in a cable anyway, why not an adaptor on the end?
I do sometimes use the storage expansion cards, as I’ll sometimes use it as a cable-less laptop while the card is plugged in and that way it won’t get caught on anything.
You’ve all given great and helpful replies, thanks! I’m currently leaning toward 4 USB-Cs and picking up a USB-A, SD card, and Ethernet card with my order or later on when the stylus is available for purchase.
I’m interested almost nobody says ethernet cards?
I will be a new Linux (and Framework) user when my FW12 comes. The one time I tried running some Linux images on my machine from a bootable USB drive, I had to use a hardwired ethernet cable to download drivers. Admittedly, this was for a fairly old Mac Mini.
Are yall just taking it on faith that the wifi will work with the supported distros? Do I have an outdated impression of Linux and hardware “just works” now? Something else I’m missing? Thanks for your thoughts.
Depending on the Wi-Fi-chip it should be usable ootb. Which means you just have to configure it (ssid, password,etc.).
I ordered a Ethernet-extension, even if I have an USB–Ethernet laying around here and will use the notebook on an usb-hub with Ethernet when on I’m on my desk.
I think there should always be an option to use Ethernet because it’s more stable, has more bandwidth and is just hassle-free.
The easiest and cheapest way will be an ordinary usb-Ethernet-adapter
Basically yes. The Intel WiFi cards have very good Linux compatibility. I wouldn’t worry about that, even using some more niche unsupported distro.
The only reason to get an ethernet card is if you’re some network engineer or if you have no (fast) wi-fi.
I got 1 USB-C, 1 USB-A, 1 microSD, and an HDMI but i plan to leave one port open for a custom expansion card (dont know which yet)
Reported for personal attack.
:rofl:
I have 700mbps wifi, and I still choose ethernet /shrug
try finding 5gbps wifi
