This is pretty cool, but why does it have that extra block on top? Also appears the notch for the screw driver is filled in for some reason:
I love the expansion for the ethernet… so, how about a 4/5 BAY that uses the extra space from where slots where the ethernet card isn’t to hold the framework screwdriver? That would be awesome!
I think the extra block on top is an error. I sliced it off in the slicer (lol) before printing. And yes I still need to grind out the screwdriver notch…
It’s a support enforcer when slicing with Prusa Slicer to print the overhangs correctly ^^ It is a bit tedious, but was also the easiest to print and design
I never used prusa slicer before, wasn’t aware support needed to be baked into the model. I use cura and it will add support for me, which makes it easy to remove. The way this model has blocks filled in, unfortunately, messes it up in the slicer I use. Nice work on the model, but it’s not usable for me in this state.
The USB-C holes ended up being a bit too small when I printed this. Any recommendations on the best way to open them up? Careful Dremel work?
Properly calibrate your printer and reprint. I use an Ender 3 and after all the standard calibrations (tightening belts, wheels, and calibrating extruder), I still need to set Flow rate to 85% in order for it to print things in the proper dimensions.
Seriously, thanks for this. I can’t wait to print this when my FW16 arrives!!
Oh, I did not know that other slicers would just add this support enforcer as a block to print
I updated the files to include all STL as standalone downloads! Happy printing ![]()
