Problems Using OpenOffice Writer to Save Documents, Related to Fan Normal-Warm-Hot Functioning Overheating Things?
I have used my GreatWhitesCanesDophinsHeat@GMail.com to contact in past, but it is constantly getting full & is full now, that I am using this G-Mail.
Laptop: 12,
Processor: 13th Gen Intel(R) Core™ i3-1315U (1.20 GHz),
Windows: Windows 11 Home Single Language,
OS build: 26200.8457
Experience: Windows Feature Experience Pack 1000.26100.304.0
I created the following paragraph as the following problem was a constant issue, now the issue is not blocking me from Saving, but…
I tried to save a document, created through OpenOffice Writer, that I have used for years, cannot remember this happening before & trying to use Save As feature, even though the touch pad was working, even though the Save As box would come-up, for a couple of times, it first told my the intended file name was invalid. So I continued to work on it, taking what was supposedly invalid & then shrinking it. After I shrunk the file name, the Save As box stopped coming-up. I clicked on it multiple times, then I figured I would try to clicking on the bottom task bar’s shortcut (from original OpenOffice Writer’s document window) & load-up a new OpenOffice Writer’s document window & copy & paste the document into new OpenOffice Writer’s document window.
So I tired that multiple times, with no new OpenOffice Writer’s document window(s) coming up. Then out of nowhere the original OpenOffice Writer’s document window closed, without any message given why. When I tried to reload a new OpenOffice Writer window with the original document inside of it/replace what I had, through OpenOffice Writer’s desktop shortcut, knowing OpenOffice feature had this as an emergency feature. When I tried to use the emergency feature (had displayed that the document was indeed rescued for me), but as you can see in the PIC, when I tried to start recovery, I received an unbelievable message, >>>>>Object not accessible. The object cannot be accessed due to insufficient user rights.<<<<<. I am the only listed user, when download OpenOffice to this Frameworks’ LT. I cannot figure-out how I am going to get that document back?
…Just a while ago, I was having trouble of getting OpenOffice to load-up a file, saved on the LT, until I plugged-in my thumb drive & used the same file from there (it worked), while the LT location where the fan is was flowing from normal/working-warm-hot temperatures.
Is this related to the previous problem of the LT’s fan functioning too hot, I know just 90-mins. or so ago it was moving back & forth from fan working to way too warm to hot?
