Personally I ordered my flasher yesterday. Far too many reports of bricks for me to roll the dice without a recovery plan in place. Hopefully I never have to use it.
It’s a device that you can attach directly to the firmware chip on your motherboard, and then write whatever you want to that chip.
If your firmware gets corrupted by the 3.20 update then normally your laptop would be a brick since it won’t boot. With a flasher, a 2nd (working) computer, and the right firmware file, you could open up your laptop, attach the flasher, and use your 2nd computer to write directly to the firmware chip.
Very true. If there is a questionable BIOS the UEFI method is the most “offline” approach and generally the safest.
Though BIOS updates are getting more complex (as they have gotten more advanced). I miss the days when booting to a USB and it just called BIOS packages in a batch file.
If one didn’t work you could modify the batch file and force the next update in line that needed to be done if it broke itself.
This still doesn’t excuse Framework from refusing to replace bricked mainboards that are “out of warranty”.
Before the BIOS update, the mainboards worked. After the BIOS update (provided by Framework), the mainboards didn’t work. Framework is at fault here, regardless of the warranty state.
The proper solution is of course to not provide BIOS updates that brick working laptops in the first place.
Have you opened a support ticket about this? Your being out of warranty should not prohibit you from opening a ticket - it just makes it much less likely you’ll get a new mainboard in the post.
Indeed it looks like its necessary. Looks like 3.19 wasn’t sent to production on the LVFS, I had to enable `fwupdmgr enable-remote lvfs-testing`.
i could then upgrade to 3.19 and then to 3.20 successfully.
