RDSEED32 is broken, disabling corresponding CPUID bit
So i noticed after updating zorin os a few times.
I started to get RDSEED32 is broken, disabling corresponding CPUID bit and idk if this is just a software issue or actually a hardware?
It does thought still boot and i cannot really see anything different.
It’s a bug in AMD processors that was mitigated in recent kernels by disabling rdseed32 CPU feature. Framework has nothing to do with it. Hopefully microcode update would eventually resolve it, if at all possible.
This stems from a Zen 5 microcode issue that was discovered in early October.
The Linux kernel was patched to disable RDSEED32 for all Zen 5 chips a few days later. The issue has since been resolved and the kernel feature disablement removed for patched systems, but the updates have not yet made it to you.
Microcode fully fixing the issue began to release in November. For the AI 300 series, that’s version StrixKrackanPI-FP8_1.1.0.0e released on Dec 15. It does not yet seem to be included in linux-firmware. Kernel 6.18 and later (and back-ports) correctly handle disabling RDSEED32 only when running unpatched microcode, so when the update ships from your OS or from FW in a UEFI update (the latest version UEFI 03.04 ships version StrixKrackanPI-FP8_1.1.0.0c) the kernel will handle allowing it to remain enabled again.
Fortunately you shouldn’t see too much direct impact since it’s mostly used by other libraries that handle the error safely already.
You can read the history of the incident in these articles:
Thing is when I first installed zorin os 18 pro it didn’t throw this message. It came recently after I did a update, after that it appeared.
As @Korvin said, “it is a bug … mitigated in recent kernels.”
Considering you updated your operating system, you probably got a more recent version of the kernel. The more recent version of the kernel mitigates the bug, and produces the message.
Just to be clear: the bug was always present. The old kernel just didn’t tell you about it.
Well according to some posts bug hasn’t always existed, some say it’s a bios issue and other say it’s a kernel issue.
So I’m confused, if it’s a kernel issue then I guess older kernel has a modification that disabled something so this message didn’t show. While newer kernel doesn’t have it? So then it shows.
Maybe not “always”, but it existed widespread in Zen 5 for a while at least (and some earlier versions of Zen as well actually).
Neither. It is a CPU microcode issue, and it affects all Zen 5 CPUs of the models mentioned in AMD’s buelltin. Later kernels have mitigations for the microcode issue, so you only see the warning now that you have updated to a kernel version that includes the mitigations.
It’s the other way around: older kernels did not have mitigations for the issue, so the issue still existed in the microcode, it was just not handled and reported by the kernel. Newer kernels mitigate and report the issue when they detect unpatched microcode. Once you get the updated microcode, you will no longer see the warning as the kernel will recognize that the issue is no longer present and does not need intervention or reporting.
Well it seems my zorin 18 pro did have something in older kernel since it had kernel 6.14 but was updated to 6.17 recently and now after another update this message appeared, it didn’t show on kernel 6.14 so it must of been a patch/modification in that kernel that disabled the message or something.
older
kernels
did
not
contain
this
message.
the message is new.
the bug is not.
you are seeing the message now because you upgraded to a kernel which contains the message.
Mind calming down for god sake?
You don’t have to yell at me.
Since typing like THIS ALL THE TIME is a way to yell at someone.
